Clarion DXZ545MP CD Player Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clarion dxz545mp amp guard issues
I have a clarion dxz545mp stereo, with an alpine amp..when my car is cold I get an "amp guard" message..as soon as my car warms up everything functions..How can I fix this problem
  • drifter711 Mar 16, 2009
    i have a similar issue but mine started during some extreme cold and now it just alwase has amp guard even when it warms up
Anonymous
Level 2:
  • Expert 239 Answers
  • Posted on Aug 19, 2010
Anonymous
Expert
Level 2:
Answers
239
Questions
0
Helped
169129
Points
587
, the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
check all of your speakers
1helpful
It says amp guard when i turn it up
Sounds like you have speakers that are wired incorrectly. Most car stereos require a 4-ohm load, if you wire two standard speakers in parallel it will create a 2-ohm load and cause this condition.
1helpful
Clarion DXZ545MP in yacht . charter client usedan mp3, pulled it out and the receiver would no longer get satelite radio, It also wqould not receive satelite radio from tv receiver qwhen on AUX. The name...
Have you tried 1st to pull the unit out of the wall using the little metal "keys" to release the deck from the mounting cage and than pull the power plug AND the Satillite plug as well and wait for 10 minutes or so and replug it but first hit the reset button and see what happens. I run into this frequently with Clarion's in boats/yacht, not sure why but i guess it could be result of a voltage surge. Now the display is saying that you have a blown speaker or more than likely a wire that is grounded out. I highly doubt the charter client caused the head unit to shut down other than the simple act or ejecting a cd. We quit selling Clarion for that very reason, an abnormal rate of repair occurances. And I would wager you have the hard wired remote controls either on the bridge or in the rear at the swim platform or both locations. These too could be the problem. I can't tell you how many hours i have spent running down a shorted speaker wire. Because if one is shorted in the "slightest" you get the message "amp guard". If push comes to shove Captain i recommend a small amplifier and use only the pre-outs (rca cables) instead of speaker wire. Good luck and let me know if i can assist you because i work on a lot of watercraft believe it or not in Arizona and most are over 34' Cuddys like SeaRay SunDancers etc. good luck... Mark @ Sounds Good to Me [email protected] if you want to reach me direct. I still have Clarion contacts too.. mark
1helpful
Clarion boat stereo- Error 6
well over time the cd reader in side the unit goes and that what is happen to your unit best solution replace the init
1helpful
Setting the time
here is the owners manual for that stereo
http://www.clarion.com/ca/en/MungoBlobs/754/615/DXZ545MP(Manual),1.pdf
please take a moment to rate this solution.. thanks
1helpful
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
1helpful
I have a DXZ648RMP Clarion car Stereo that says amp guard
3helpful
Clarion DXZ385USB
Check your Factory speaker locations for blown speakers or bare wires to metal.
CLARION DXZ545MP
No, the RCA plugs are used for connecting to an amplifier only, they are not powerful enough to drive speakers directly.
Clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
