I have been trying to download Dictionary Boss toolbar. it gets to the point where it asks me if i want to RUN. i click on RUN and after a while it says: SECURITY CHECK IN PROGRESS. after that it asks me again if i want to RUN and i click on RUN and nothing happens. can someone pls. help me get this toolbar downloaded. Thanks.
SOURCE: can't get to disk defragment my laptop
Try using the FSUTIL DIRTY command to query and set the dirty bit on the volume. This essentially tells Windows that there is a file system error on the volume and it needs to run chkdsk next time.
http://technet.microsoft.com/en-us/library/cc753059.aspx
At the command prompt, type FSUTIL DIRTY QUERY C: (or whatever your drive letter is) and get the status
Then type FSUTIL DIRTY SET C: (this sets the dirty bit).
Reboot. Chkdsk should run properly and reset the dirty bit automatically.
As for defragmentation, check out Diskeeper 2008. It's by far the best defragmenter available (Diskeeper invented the defragger for Windows!). No, it's not free, but you can get free trial versions from the Diskeeper site http://www.diskeeper.com
download the latest audio driver from here http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=VOS_N_1510&os=WLH&osl=en&catid=&impid=
make sure you download the one for your operating system
SOURCE: I am trying to restore my Dell Inspiron 6400 to
If you want to reformat to factory condition, then press Ctrl + F11 at start-up when the blue bar comes up with "Dell.com" on it. If you miss it then just let it start up, then restart and try again. If it still does not work, press F12 at startup and select recovery option. Please note, if you have deleted the Dell Recovery Partition this will not work for you. You will need to reformat by inserting your Operating System CD at Startup and booting from that (F12).
