Question about SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry
My HD dont Work anymore
Hi, I have a SimpleTech external HD, 160GB, and it use to work ok, but today, I was recording some files on it, and my HD fall down from my bed to the floor, I try to use it again, but never works again.
When you turn it on, the Hd seems to work as usually, but then just sounds a CLICK... and the Laptop dont recognize it...
what can I do?
  • ysha17 Mar 25, 2009
    my hd cannot be recognized by my desktop computer, blue light is not blinking...
  • donovank Mar 31, 2009
    When pluged in the red light is on. The computer either doesn't recognize it or it just doesn't work other than the power. I just loaded a few files on it then it stoped working all together. We should have bought Seagate and we we would'nt have this problem. I am sure you guys are agervated with this problem as well. By the way I already took mine apart to see what the deal was. I was wondering if you were talking about the stiker in the middle that says will void warranty?
Hey! i was having the same problem, but it all seemed to be fine after i opened the case up... what you see inside is a hard drive connected to a small circuit board used to make that hard drive interface with the computer. basically what happened with mine, and probably yours was that the hard drive slipped out of the socket on that circuit board- the drop it took was probably JUST enough to make that happen, given that there's some room inside the case for it to slide a little.
if you don't mind potentially voiding your warranty, i'd suggest you do what i did:
- keep the drive unplugged from everything
- peel off the sticker underneath to access the screws
- slide the hard drive back into the socket on the little green board where the USB sockets are
- close it back up and test it out.
this worked just fine for me, and i hope it works for you too! it also saved what might have been ****-loads of money taking it to a recovery specialist :D
good luck!
- chip
Posted on Jan 22, 2009
    Scholar:
  • 77 Answers
The hard disk is physically damaged and you need to take it to a data recovery center. Ask some PC tech if they know of one close by or search on google or lookup in the yellow pages.
HTH,
Deboo
Posted on Jan 18, 2009
Simpletech external hd 250 Gb is not reckon by vista (though was before) but works ok on XP. USBs are ok. It appears in disk management (says it is working properlly but no letter asigned to it) but does...
You need to partition it and format it inside of disk manager. You can do this by right clicking on the device (the gray box next to where it said there was no letter assigned)and selecting initialize.
May 04, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I have a simpletech 250 GB external hard drive model number 96300-40001-001. I was transferring a file from my desktop to the external drive but canceled the operation because I didn't have time to wait....
May seem like a silly question you are not booting up computer with ext drive still plugged in are you?
i am assuming your operating system is on the internal drive.
if so don't have the external plugged in when you start up.
Dec 09, 2017 | SimpleTech SimpleDrive 250 GB External USB...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech Signature Mini not recognized
Dear,
Please check this drive with another new cord to connect it with PC.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 01, 2009 | SimpleTech Signature Mini 160GB External...
Fabrik simpletech 160GB external HD
Dear,
I think this is warrenty period and you should visit your nearest service center.
Regards,
Rakesh Kumar
Mar 31, 2009 | SimpleTech Signature Mini 160GB External...
SimpleTech external HD won't turn on
Get a new AC adapter for it. I had the same problem, & I had an AC adapter that was the same type for the modem & I tried that one & it was working again.
Feb 28, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Signal lights dont work
Flasher unit could be faulty,,,look near the fuse box,,easy to replace.
Jan 19, 2009 | SimpleTech Signature Mini 160GB External...
SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry Logo
276 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
