Question about KONFTEL 100 Audio Conference
Wont run fuel pooring out front of carb, n back of muffler. it has spark and compression but wont run
    Problem Solver:
  • 10 Answers
I think it may be a gasket or a bad mixture of fuel and air wich is flooding it
Posted on Feb 16, 2009
Yamaha virago y rone with choke honney the cilanderfronthis cold hand back his hot afer 4 minute ron
Your front cylinder is not running. This could be due to spark or fuel, or lack of compression.
Check for spark first by inserting a good plug in the plug wire and holding it against the cylinder. If it shows bright spark, you may have a fueling or compression issue.
Check for compression, should be around 150psi. If you have spark and compression, you probably have a fueling issue.
Check the carb for the front cylinder for fuel level in the bowl. If the fuel level is correct you have another carb issue which will require removal and cleaning/servicing.
Jul 22, 2014 | Yamaha V Star 1100 Classic Motorcycles
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Sovereign xc 375 very difficult to start, getting spark, fresh fuel, oil and new spark plug - no change. Any suggestions?
Is your spark plug wet when you pull it out? If so then it may be fludding on you, If it's dry then your carb may be gunked up from old fuel setting in carb and lines it also can plug you fuel filter. after checking all these, check your compression and also take your spark plug out and look inside the hole at cylinder foe bad scores or scratches in the wall of the cylinder, you should also pull muffler off and check cylinder that way too, you may be low on compression.
Another thing you could try is your air filter, is it plugged with sawdust, take off and try that , then try carb clean short blasts into carb and try to start, then work choke back and forth keeping it running to help **** some fresh gas through carb, all else fails pull carb and dissasemble and clean. Good Luck
Apr 26, 2011 | Garden
Engine will start but wont run when throttle is applied
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Mantis Tiller
How do i set the carburetor on a Stihl FS-55 weedeater.
Over the past 8 years, the FS55 has had at least 5 different carburetors, and they have at least 3 different systems with different adjustments. Many of them do not have much of an adjustment and will not cure running problems. If you are experiencing poor running conditions, I would suggest some basic checks first. The spark arrestor screen is a big culprit on this model.
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 23, 2009 | Garden
Will not run (dies) at full speed
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 20, 2009 | Craftsman 4 Cycle Blower/Vac
Homelite bx90 leaf blower: won't run in cold weather
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 15, 2009 | Homelite 'Yard Broom' Leaf Blower
Eb 431 has been running great! Started it
No-start
Basics to check:
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 13, 2009 | Garden
Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Aug 17, 2009 | Honda 6370C - Parallel Power Kit For ...
KONFTEL 100 Audio Conference Logo
175 people viewed this question
Top KONFTEL Lands Phones Experts
Are you a KONFTEL Lands Phone Expert? Answer questions, earn points and help others
