Question about Xerox DocuColor 12 Printer
I just purchased a docucolor 12 from ebay without a fiery controller. I observed it has a parallel lpr port can I use a standard connection from my pc to run this printer
Nop, you need a Fiery X12, xp12 or Ex12 or splash system in order to print
Posted on Jan 22, 2009
I have a docucolor 12 and x12 fiery. I am trying to calibrate from the fiery. It will printer calibration page, but it can't measure scanner. It comes up with check scanner cable connection. I have tried...
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
Jan 02, 2011 | Xerox DocuColor 12 Color Copier
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
I have got a Xerox Docucolor 12 printer, a Fiery X12, and a laptop running on Vista. I dont have any cables except the power cables and was looking for a list of everything I'd need to get it running...
There are 2 cables that go between the fiery and the printer, not sure where you can get these.
You will need to be running windows xp
connect to the fiery with an ethernet line
download the drivers, command workstation, and fiery remote scan from the xerox website
hopefully the fiery still has its software loaded otherwise post a request for a copy here.
Nov 11, 2010 | Xerox DocuColor 12 Printer
No matter what i do i cannot enable TCP/IP or Parallel port. I enable through the system setup but when the fiery restarts and and the test print is printed it just keeps telling me TCP/IP enable :NO and...
Is not simple if you don't the program. It find in www.support.xerox.com . When you install the driver , please connect the printer, TCP /IP must be static IP and not DHCP. Because the ip is change when the swicth is desconnect.
Nov 03, 2010 | Xerox DocuColor 12 Printer
Can you scan to file on the xerox docucolor 12 with the fiery x12 color server
yes it needs one printer cable and one scanner cable connected between fiery and machine
and scangear software install and remote compputer
Apr 23, 2010 | Xerox DocuColor 12 Color Copier
Xerox docucolor 3535 error 016-387
I've seen plenty of these issues with Fiery's connected to all manner of printers.
Actually, 016 errors are network related issues. The 387 usually indicate an issue with tthe switch device that the fiery is connected to and not the fiery itself. Get the connection from the fiery to the switch checked out and also the port status on the switch itself. Also recycle the Xerox and Fiery and you may also have to recycle the network switch as well.
Sep 14, 2009 | Office Equipment & Supplies
Xerox fiery server
Fiery.1 usually does the trick
Mar 03, 2009 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Not Printing with another Fiery
could be a few things, the ips pwb in the machine might be faulty, which can cause these types of issues, a driver issue woth the video boards on the fiery, or other pwbs on the machine itself. You would have to run the machine for a while on another fiery to make sure no other faults occur before condemning the machine or the fiery
Jan 17, 2009 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
277 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
