Its part of the tuner in most cases and not real easy to replace for a novice---sometimes the tuner will have to be replaced as when it broke off it may have damaged the circuit board inside the tuner.
there is a possible way around this: With a box of any kind being used that has the Audio/video jacks for output of signal you run cables from them to a set of matching inputs on the rear of set, leave set on that input and change channels with the box--bypass the tuner completely.
If the tuner and board it is only sold as a complete unit it will be expensive to repair.
SOURCE: broke HDMi connector on TV
If you are talking about the part connected to the tv, you need a new part. Investigate ! In the meantime use a S Vidio plug, or the red, white and yellow cables to get you going.
SOURCE: TV input on the back of the unit broke cant connect coaxial cable
Try entering the model number on website below, they do worldwide delivery, and have one of the biggest database of replacements.
Appliance parts, electronics parts & more from PartStore.com
SOURCE: cable connection broke off bake of unit
if i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
