I recently bought a 640GB drive for my G5 mac running leopard. I plugged it in, and the drive began working immediately. I ejected the drive, and then I unplugged the drive from the wall. When I plugged the power chord back in and tried to mount the drive, the power light indicator flashed slowly for a minute, and then the power light went out completely. I checked the wall outlet for power and the USB port to make sure both were in working order. Then I checked both the power chord and the USB cable to make sure they were both plugged in correctly to the wall, computer, and the drive itself, and they were all connected. Yet, I still have no power to the drive, and it will not mount.
  • 3 more comments
  • johnj_bnm Jan 16, 2009
    Yes. I have power to my entire computer. I even try unplugging another USB port that was in use by another piece of hardware to make sure I was using a working port.
    I'm not sure what program you are talking about. There was no install software required to run this hard drive on a mac. Only setup software for dealing with a PC.
    I'm not sure what you mean. There is no software required for running this hard drive on a Mac. There is only install software for setup when using it on a PC.
  • Paul Tilley May 11, 2010
    Are you able to run any other USB device on your Mac using the same ports the drive was plugged into?
    If you can then the USB ports are fine, if you can't run any other device from the same USB ports that is where I would start to find the issue.
    If it turns out you can run other USB devices, do you have another hard drive you can put into the external enclosure to see if that hard drive can be mounted?
  • DEKR
    DEKR May 11, 2010
    you may have knocked something else is your system out
    you have power to everything but the drive
    Problem Solver:
  • 29 Answers
It sounds like the drive is defective. It happens if the resistors are not soldered properly and the drive gets blown out. This drive should be covered under warranty and should be RMA'ed ASAP. This is a common problem with External drives.
Posted on Jan 16, 2009
    Genius:
  • 1,102 Answers
Can you run the program again
if not there is a website for getting it up and running
  • DEKR
    DEKR Jan 16, 2009
    k
    sometimes too much memory can freeze it
    can you remove one of the memory and then try again
  • DEKR
    DEKR Feb 09, 2009
    inappropriate rating would be okay if i gave a solution or asked you to try something that had nothing to do with your problem.
    You quit conversing with me which is okay but in that case it should have been a thanks for tryin
Old 2005 apple mac upgrade
Leopard requirements/10.5.x...
* Mac computer with an Intel, PowerPC G5, or PowerPC G4 (867MHz or faster) processor
minimum system requirements
* 512MB of memory (I say 1.5GB for PPC at least, 2-3GB minimum for IntelMacs)
* DVD drive for installation
* 9GB of available disk space (I say 30GB at least)
Classic/OS9 Apps no longer supported.
$45.00 on Ebay.com - You can't do Snow Leopard.
Jul 22, 2013 | Apple iMac G5 Desktop
Getting a imac g5 all in one power pc 1.8 gb os x 10.3 computer. can i upgrade to snow leopard v 10.6.3 with disc ?
Unfortunately Snow Leopard requires a intel processor to work so the G5 imac will not be able to run the system.
Jun 24, 2011 | Apple iMac G5 Desktop
Rev 35GB Firewire suddenly began ejecting any inserted disk after about a minute of blinking light. connected to Mac G5 - os 10.5.8 Replaced power supply about a year ago.
So any disk produces this result? You may have a bad drive, but without further explanation, it's really impossible to say.
May 14, 2010 | Computers & Internet
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
Jan 06, 2010 | Apple Power Mac G5 Desktop
I Have a MAC OSX 101.5 can I install leopard
Here are the minimum specs your Mac will need to run Leopard, from Apple:
  • Intel, G5, or 867MHz+ G4 processor
  • 512 megs of RAM (though if you only have 512 megs of RAM you should get some more. Trust me, I'm a pundit)
  • DVD drive (Leopard is shipping on a DVD, and your Mac needs to read it to be able to install it)
  • 9GB of free disk space (though I bet if you customize the install and leave out all those printer drivers and extra languages you can save lots of space)
Go to your apple menu, and look on the "about this mac" If your machine doesn't have the mhz's you are out of luck. If you don't have a DVD drive, you are not going to be able to install either...
K
Sep 14, 2009 | Apple iMac G4 Desktop
Leopard OS
Is the hard drive SATA or IDE. On IDE, I know you can use delpart. Locate a SATA tool to wipe the partition of SATA drives. Install LEOPARD as usual then after rebooting.
Jul 25, 2009 | Apple Power Mac G5 Desktop
No Power to new 640 My Book Drive
John, Ejected or unmounted may be the difference.  Have you added the drive?  If you only power it up occasionally for back-ups you would leave it off, but for everyday use once it is added you can just leave it on and after you power down then turn it off.  randy320sgi
Jan 16, 2009 | Western Digital My Book Essential Edition...
Can't install Mac OS X Leopard on Power Mac G5.
email me at glenn@light.on.ca i have the fix for you
Nov 20, 2008 | Apple Power Mac G5 Desktop
Installing new system software on G4 imac where system removed
Well the flashing question mark means its not finding a bootable device meaning the hard drive has no OS on it. You should be able to put jaguar on it if its a retail version and not one from another mac product. Let me know how this works for you
Nov 16, 2008 | Apple Power Mac G5 Desktop
Leopard won't install
Found this on the net:
http://www.brad-x.com/2007/10/27/howto-leopard-install-with-giga-designs-g4-upgrade/
Those upgrade cards always have given me a problem with migrating to Leopard. If you can upgrade to a used G5 or even Intel basd mac you might be more happier with less hassle.
Aug 11, 2008 | Apple Power Mac G5 Desktop
Computers & Internet Logo
David Payne
David Payne
