The Panasonic NN-S960WA (may be identical) has the fuse at back, right, on top, & inside the cover. The screws are tamper proof screws. You can create a slot in the heads (2 screws) with a hacksaw blade and open with a flat blade screw driver. Don't forget to unplug the unit first.
It's usually located on the floor of the oven behind the control panel, or with the door switches. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
I push the start program. I get a continous buzz. The oven will run about 6 seconds and then stop. I have checked the turntable, the circuit breaker and the wall plug. I tried unplugging it overnight. Nothing works.
Power suddenly died in Panasonic microwave. Only used 2 months. Can someone tell me how to replace a fuse and where to buy one? It's not the circuit breaker or the outlet.
