Question about Panasonic NN-S960WA Microwave Oven
Panasonic Microwave I have Panasonic NN-S960WC-F microwave. I can't power on and I think I need to replace the Fuse but don't know where and what type of Fuse I need. Some of the screw heads are weird star shape. Please help.
  • revis70230 Dec 18, 2008
    NO POWER TO NO PART OF OVEN
  • Anonymous Mar 14, 2014
    How to replace lightbulb
  • 5,911 Answers
The fuse is usually a 250V 15 or 20 AMP and can be found at any hardware store. As for those screws...those are special tamper proof screws made to keep the average consumer out of dangerous appliances. There's about 4000 volts inside a microwave oven when it is energized. That's why the manufacturers don't want the average Joe tampering with it. You can, however, buy the tool required to get inside the unit for a reasonable price. I think it's less than $30 and I know Craftsman makes it. The line fuse is located on or near the input line filter board. Just follow the input power cord and you will find it. Just keep in mind, that if the fuse is blown, it usually blows for a reason. You may have other problems. Let me know if this helps you.
Posted on Jun 23, 2007
Where is the fuse on Panasonic NN-S252
You may have to remove the cover on the microwave to find a fuse. It may not be either in a fuse holder or soldered into a the circuit board. be sure it is not plug up when you check.
if you find it be sure and replace with the fuse with same current rating.
Aug 01, 2014 | Panasonic NN-S252WF Microwave Oven
I need a new door inner glass for Panasonic NN-A772SBBPQ microwave/combination oven
Think about calling up the Sears 800-4MY-HOME line... the parts dept can look up your model with the LIS and have the part sent to your address and a Tech to install it for you if you don't know how, plus if you do pay for a tech repair for like $40 they do a clean and prevenative maitnence check on any other appliance you may have thats acting weird.
Mar 07, 2012 | Panasonic Microwave Ovens
There is no power coming into my microwave which is a panasonic nn-L531WF model. I think it's the fuse. How can i change the fuse?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | Panasonic NN-L531WF Microwave Oven
I belong to thiruvalla and need to service my panasonic microwave oven(NN-C784MF)-28L.I need to know the best person to call.
Due to the type and design of your microwave oven, consult an Panasonic authorised service centre.
www.panasonic.com for a list of dealers in your area.
Jan 07, 2011 | Panasonic NN-S541 Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Oven will not turn on. No Power at all. Does this model have a fuse and if so where is it located?
Yes there is a main power fuse. It is situated where the power cable terminates, within the unit.
It is a special type of fuse and MUST be replaced with exactly the same type and size.
Oct 18, 2010 | Panasonic NN-H504WF Microwave Oven
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
Microwes panasonic nn-t553w
hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
Mar 06, 2009 | Panasonic NN-S753 Microwave Oven
Microwave
It's usually located on the floor of the oven behind the control panel, or with the door switches. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Jun 17, 2007 | Panasonic NN-S960WA Microwave Oven
Panasonic NN-S960WA Microwave Oven Logo
574 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
