Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Double vision On JVC AV-56WP74 56
I have a JCV television. Model# AV-56WP74. The red color is to the left of everything. All figures and letters look like double vision. The converge will not merge the red with the other colors and the manual does not work either. I have only had it about 2 yrs. Thanks for any help.
  • 41 Answers
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Posted on Jul 02, 2007
  • Charles Aron Jul 02, 2007
    Resolder the cold joints if you can see small
    rings around the pins of the IC, this corrects this problem without need of a service technician.
Blue &yellow lines, double vision on most numbers , letters cannot adj convergence or even remove color
This means that a part is failing.
Check the boards for bad connections, and bad parts. IT could be in IC that is bad too
Aug 18, 2013 | JVC AV-48WP74 48" Rear Projection...
Two lines run thru causing overlay or double vision,example word is white with red showing behind av-48wp74 email howardselectric@hughes.net
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | JVC AV-48WP74 48" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Jvc 56wp74
sounds like a solder related issue on the convergence ICs. They are acessed through the front of the TV behind the speaker grille and then remove the small acess panel and you will see the convergence amp board with the two ICs on it.
Oct 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Did the convergence procedure but not sure its my problem
Hey, I have one model JVC av56p776 doesn't work anymore and don't know why, there is just no power going into the TV, anyway, I'm willing to sell it for 50 dollar if u want to salvage for parts. Contact me if you wnat it.
jinx611@msn.com
Aug 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
JCV HD Convergence Problem.
Replace both convergence IC's......Please confirm Model #
off back of TV and I will help you step-by-step....Requires
above-average soldering skill......................T.
Nov 18, 2007 | JVC AV-48WP74 48" Rear Projection...
Jvc model av-56wp74
Needs convergence IC's replaced..........T.
Oct 06, 2007 | JVC AV-27850 27" TV
Tv screen waves and is double
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
Jul 12, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
167 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
