Question about E-Machines (T2824) PC Desktop
Motherboard Hi. I recently aquired an older e-machine from a friend. He told me that the power supply and hd were both fryed. I figured i would buy anew p/s and hd and the pc up and runing again. I tried that but nothing happens, just a green light on the mobo. Someboby told me it is problably a bad mobo, but how can i figure this out
  • Lamar Ryan
    Lamar Ryan May 11, 2010
    Does the computer boot into the bios?
    Champion:
  • 219 Answers
Could be the CPU...
Posted on Jan 24, 2009
I recently purchased a new Radeon 7970 graphics card and installed in into my computer which currently is... --AMD Phenom II X4 965 Black -BIOSTAR TA790XE -600 Watt OCZ mod x stream-pro power supply...
Hi David,
Try removing and resetting the CMOS battery on your motherboard. Also, make sure that all connectors from power supply are plugged into the motherboard. There should be power for sys fan, CPU fan, etc.
Thanks,
E.
Sep 20, 2013 | Computers & Internet
Pin out for a dell PS-5201-8D2 power supply
Use caution, some older Dell machines used a non standard, proprietary pin-out on the 20 pin connector ALso the 6 pin is suspect. If you connect a regular ATX PSU, you will fry the MoBo. Look here
DELL ATX motherboard Power Supply pinout
Jan 23, 2013 | Dell (PS-5201-8D2) (PS52018D2) 200-Watt...
Power suppy fried, now new power supply will not power up
a 450 watt power supply will have the extra pins your talking about if this is a newer pc if not you will have to buy older used one on ebay or something to get what you need
Nov 10, 2009 | MSI K8T Neo-FSR Motherboard
Plugged the computor into too high of voltage. i.e. 24v instead of 19v. Was told this has blown out motherboard
What you have been told is probably correct, plugging a much larger power supply into a device that is made to take less voltage will in 99% of cases fry the components on the motherboard rendering it useless so yes the motherboard will have no doubt blown out.
Regards.
Aug 18, 2009 | Toshiba Computers & Internet
No power
Could be you power supply... try one from another machine.
Apr 04, 2009 | Gateway 3250S PC Desktop
No power what so ever!!
power supply could be dead in which case buy a new power supply, unless the motherboard is dead.
Mar 23, 2009 | E-Machines W3050 PC Desktop
New motherboard drivers
Hi
Sounds like the BIOS corrupted while updating. It's usually easiest to just buy a new motherboard. As for the second one could i please get more information. Is it new? Are you 100% it's plugged in correctly? They usually don't just do nothing. You usually get a sequence of beeps alerting of an error. This may mean a power supply issue.
-Damian
May 01, 2008 | ASUS M2N-E SLi Motherboard
Lights on but no one home...
This could be one of many things: First off if the set up is new and you just put it all together try removing all the IDE/SATA cables and see if that helps. If the machine then boots you know one of those devices is faulty or setup wrong. If that does not help, remove the RAM modules and try again - this may invoke a different error as the board may not want to boot without any RAM but you should notice a change. If no change then it could be the CPU or power supply unit (PSU) The MOST likely problem is that the PSU has given up or is not producing enough juice or is producing too high a voltage. The only way to check this effectively is to try a different PSU. I had a customer who brough me a machine which had stopped booting. He was told by a "friend" the CPU & mainboard had failed so he bought a new CPU and mainboard. The machine still did not boot and in fact the power supply was producing to high a voltage and had fried the mainboard and CPU. Then it fried the second CPU and mainboard he put in. Expensive mistake... so make sure you replace the power supply (or have it fully tested buy an expert) BEFORE you add any new parts to the set up.
Jun 19, 2007 | Acer (ACERMOTHERBOARD)
Mach speed motherboard problem
I had the same problem once. I took it to CompUSA to have them diagnose the problem, and they said I fried the motherboard or CPU. The fans turn on just because your power supply is on.
Jan 14, 2007 | Mach Speed P4M800 (890552603480)...
E-Machines (T2824) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
