Question about IOGear GCS632U 2-port KVM Switch
KVM unresponsive Hello! My name is Greg, I JUST bought the IOGEAR 2-port kvm so I could switch the keyboard and mouse between my two systems. One system is running Vista Ultimate x64 (the kvm works when I plug it into this system) however when I plug it into my Windows 2008 Server, I dont even get an indicator light on the KVM... any help would be great.
  • 2,923 Answers
Since you are not getting a light indicator on the port where the Windows 2008 is connected to, try swapping the ports or the cables. If the problem follows the Windows 2008, try connecting the KVM switch into different USB ports of that computer.
You may also try power cycling the KVM switch, by disconnecting it from the computers and leave it disconnected for two minutes.
After two minutes, reconnect everything back to the computer.
Posted on Apr 08, 2009
  • 30 Answers
Try swapping the KVM cables from the 2008 computer into the Vista computer and see if the problem follows the 2008 computer. This KVM gets the drivers it needs from the OS and the IOGear web site does not show any support for 2008.
Posted on Jan 21, 2009
I have an IOGear GCS1734 KVM switch and two Windows based machines. I work for the gov't and we have to use a CAC Card. My keyboard has a slot/reader for my CAC card to verify my credentials. If I...
As far as mouse is concerned all you need is PRACTICE, and there may be a compatibility issue with your keyboard or the wire you are using is not fine, coz the kvm switch is definitely ok when used with 2 systems.
Oct 19, 2010 | IOGear USB gcs1734 4-port KVM Switch
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Not switching systems
Make sure your keyboard is plugged into the keyboard port of the KVM. The IOGear KVMs use a keyboard and mouse emulation. Due to this the keyboard port is the only port will recognize the Scroll Lock command.
Oct 12, 2009 | IOGear Computers & Internet
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
GCS5632u KVM swith working with Vista
Make sure the keyboard/mouse receiver is connected to the keyboard port on the KVM -- there is an embossed icon near each port -- mouse and keyboard.
Jan 01, 2008 | IOGear GCS632U 2-port KVM Switch
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
851 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
