Question about Craftsman Saws
Band Saw Blade won't stay on
Recently obtained a Craftsman 10" Band Saw Model 113.244513. The blade was not on it. Found a manual online and thought I did everything according to the directions but every time I turn it on the blade runs off the wheels.
  • 1 more comment
  • joc_48 Jan 18, 2009
    The directions said to align the back of the saw blade to within 3/32ths of the rotating guide, and I thought I had this about right. Should I try again to get this closer to the blade. Not sure what you mean by bottom wheel tilt adjustment? Thanks, Jim Carlan
  • joc_48 Jan 19, 2009
    Thank everyone who offered a solution to this problem. Finally solved it. Although the directions in the operators manual does not say this, the solution was that the upper wheel must be loosened by means of a screwdriver, then the tension adjusted, then the wheel must be tightened again. First time I did this blade stayed on and tracked perfectly. Saw now cuts like new. Thanks, again all who responded. Jim Carlan
  • Thomas F. Schneider May 11, 2010
    Band saw guide which alignes with the back edge of the blade. Ajust so that the blade just oor almost touched freewheeling. Bottom wheel tilt ajustment/
    President:
  • 2,692 Answers
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
Get a 12 "Sears craftsman band saw blade model no 113.279521c
I'm using Haltbar band saw blades that I got from sawblade.com . They have great quality band saw blades. I ordered 10 blades from them last month and shipping was free.
Oct 18, 2014 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
What size blade for a craftsman bandsaw 113247110?
Your band saw uses 10" band saw tires and a 63 1/2" band saw blade. . Get band saw blades on sawblade.com
Sep 03, 2014 | Saws
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
Manual 1987
In my search, this is the closest band saw to 11.324200 that have almost the same structures and features. 113.24201 band saw . You can download the manual from there. If you need a blade, I recommend you to visit sawblade.com , they custom made blades, I ordered my blades from them .
Dec 22, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Oct 17, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Manual for 1.3 hp Craftsman band saw
The blade length of the saw is 70.5" . You can get custom length blades on www.sawblade.com . You may visit sears site to get manual for that saw.
Jul 26, 2013 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
Feb 11, 2013 | Craftsman Saws
I am looking for a manual for a Craftsman 10" Band Saw Model No. 103.0101
I have a 10" table top bandsaw and i need to replace the drive belt. Can't find a manual for this and don't know the size of the belt.
Aug 14, 2010 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Blade tension on a craftsman 12in band saw mod. # 137.224320?
OK go to Searspartsdirect.com and on the right hand side under model type in your model number it will take you to another page and on the right side you will see a box for manual click on it, what you will have to do is set up a FREE account to download the manual online or just view it, the information you need is on page 10. The complete manual is 14 pages long. Let me know if you have any problems
Mar 22, 2009 | Craftsman Saws
Saws Logo
1,621 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
