Question about Linksys Wireless-G WRT54G Router
My wireless Router is not working and I can not find the disk
When I connect straight through the router it tells me it can not find a network address
  • 55 Answers
If its a desktop open it up and check inside to see if the modual is conect propurley
Posted on Jan 16, 2009
Was working on my laptop upstairs and it told me I lost my internet connection. The IP address was192.168.2.1. Now all of a sudden can't assess my network from any wireless device. When I type in...
1. First thing you should do is RESET (both) the router and modem.
2. Check if the wireless and wired connections are ok.
3. Contact your ISP, let them check your status.
Jul 03, 2011 | Dynex DXWEGRTR Router
The router has been reset by mistake and I don't know how to get my connection back for laptops. I currently have the dsl modem connected straight to the house computer. How do I get my router working...
Most DSL modems have their internal network set at 192.168.1.0/255.255.255.0
which is the same address space by default in your Linksys Router... more or less the routers IP is 192.168.1.1 and the default IP of the DSL gateway is 192.168.1.1 ... following steps to fix...
hardwire a PC to the Linksys router navagate to the webpage at http://192.168.1.1 (default username *BLANK* password: admin)
first setup all wireless options SSID: (choose something other than the default "linksys" so you can tell it from all the other linksys default systems in the world), WPA/WPA2 Encryption (so only people you know can get on)
after you set all that up then go back to the basic lan setup and change the address space from 192.168.1.1 to something else (e.g. 192.168.10.1, 192.168.21.1, or so fore)
Oct 15, 2010 | Linksys Wireless-G WRT54G Router
One of my computer will not connect to the internet when hard-wired through this router. Others do work and the wireless works flawlessly. The computer in question runs XP and can communicate with the...
1. There may be 3 issues here to consider 1st :
a. the network card \
b. the Ethernet cable
c. the Ethernet port on the router defective.
2.Here is a instruction set to follow to see if your router is connected properly with the said pc :
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or firefox) on the computer that doesn't connect.
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. use a straight through Ethernet cord ( a know good one )\
8. verify that the network card is working by using a loop back ( that is ping the NIC card ( done by using dos command prompt>> loopback address is 127.0.0.1 this should yield 4 hops complete if the NIC card is working ( NIC = Network Interface Card)
I hope this helps. Have a great day!
This is for all routers to set up wirelessly.
Aug 23, 2010 | SMC WBR14-N Router
Connecting modem to WAN port then any lan port to computer provides no connection. straight from modem to comp is ok.
Make sure comp lan and wan are both activated, Make sure the ethernet cable from modem is plugged into the input slot and NOT 1,2,3,or 4
Then after all is connected, unplug main modem for 10 seconds, plug back in, then do the same with wireless router. 5 minutes later, you should be good to go.
You can access the software of you router by opening up an internet page, and type 192.168.1.1 and hit enter. It should bring you right straight to the router's firmware/software where you can change any settings if desired.
If it asks for username and password, the default is usually admin for both. (see owners manual to be exact)
Nov 16, 2009 | D-Link AirPlus DI-524 Wireless Router
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Can only connect 1 computer to router
You might need to check if your laptop is able to get a valid IP address when connected wirelessly to the router. You can go to the Control Panel then click on network connections and look for wireless network connection. Right click the wireless network connection then click properties. Click the support tab and there you will see the IP address. You should not be getting 169.254.x.x. Where X represents numbers.
An IP address is very important. Make sure you're getting a correct IP address and it should be the IP address provided by your router. Without a valid IP address, you won't be able to get onlinwe. Your wireless connection can tell you that its connected eventhough its not getting a valid IP address.
Feb 07, 2009 | NetGear DG834 Router
Connecting Ipod touch 8(GB) to Wi-fi
I want to tell you that there might be two problems for your concern.
1. Your router is not working properly
2. Your Ipod Touch is not working properly
But it might be possible that both devices working fine just the compatibility issue.
First of all i can suggest you that you can upgrade the firmware for your router.
Then you can reconfigure your wireless setting on your router.
Then tried to put static ip on your ipod touch in the network setting option
IP address: 192.168.0.15
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Primary DNS: 192.168.0.1
Secondary DNS: 4.2.2.2
Then tried again to connect wirelessly with your ipod touch make sure you dont required to add mac address for you ipod touch and also you can click on the option called "Wireless Access Point"
Then you can see the option " Turn Access Control On" you can uncheck this option.
Try again i believe that will resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Jan 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
Linksys Wireless-G WRT54G Router Logo
16 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
