Question about Motorola Mobility RAZR V3
My cellphone screen is white! [verizon blitz]
Im not sure if it got wet somehow, but i figured that would just completely damage the phone. i can turn it on, but the screen is just completely white, it vibrates like it should when turned on, but it wont allow me to do anything, no buttons work, i cant call or see anything.
this is driving me nuts! i just got this phone last month, and i dont have the money to just "buy a new one".
  • 2 more comments
  • tjac342 Jan 16, 2009
    mine got wet. nothing worked for the first day, but now everything but the screen. Well it works but it has dark spots all over. it's coniderded physical damage to, so it's not covered under warranty. paygo or contract. mine is paygo.
  • Anonymous Feb 28, 2009
    My phone was perfectly fine, until the screen turned white. it wont turn on (white) unless its in the charger, otehrwise its black
  • Anonymous Mar 23, 2009
    I have the same problem i was txting in the shower and the screen got all messed up and the buttons got screwed. i could still txt but then i turned it off really quick and i turned it on and it just blinked white slowley an idk wut to do....
  • Anonymous Mar 29, 2009
    my screen is white when i try to turn it on and then it just seems to turn off by itself....a few days before this i would have to turn it on and off all the time because it would just freeze or the screen would go black
This usually happens when you've deleted files needed to start up the phone. if you have been using p2k commander than it would be an easy mistake but if not then you could have shorted a wire by charging it for too long.
Posted on Jan 16, 2009
I dropped it and now it won't turn on
it could also be loose wiring after you have dropped it, either way someone definitely needs to open it up and take a look
Apr 27, 2014 | Verizon Wireless PCD Blitz TXT8010 -...
My Verizon Blitz won't connect to my computer
Endless hours were spent trying to connect my Motorola Razr to my computer. This finally worked:
Go to Google Playstore on the phone. Download Motorola PIM (all upper case).
If you have an extended battery case/charger on the phone, remove the phone and insert the USB cable into the port on the top of the phone.
Or
Download "Airdroid" and connect wirelessly.
Nov 02, 2013 | Verizon Wireless PCD Blitz TXT8010 -...
My blitz upper pad is frozen and wont turn on unless i plug it in
Usually a sign of moisture damage check the sensors on the battery and underneath the battery on the phone, if neither is red then you can get swapped out by the verizon store under warranty.
Jul 11, 2010 | UTStarcom Blitz Cell Phone
Well, my blitz has water damage, & i was letting it dry, & it was coming around fine. eventually it was working as good as new. then all of the sudden, it shuts back off. when i turn it on now, i...
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Jul 23, 2009 | UTStarcom Blitz Cell Phone
Black screen on inside and outside has not been dropped may have water damage from water on my hands
i know the water sticker is still white because you didnt get the actual sticker wet... in order to get the sticker to turn red... the sticker has to be wet...!
May 29, 2009 | Motorola Mobility RAZR V3
Verizon prepaid blitz spc code not all zero's what is it?
Try the last four digits of the phone number to the phone.
Mar 19, 2009 | UTStarcom Blitz Cell Phone
Screen turns white when opened
Well what sometimes happens is your phone gets confused because when your cell phone is shut the screen doesnt go dark it is a plan white screen so what I think happend to your phone is that the sensor that is on your keypad is messed up somehow and thinks it is open when its shut.
The same thing happened to me before but my phone got wet.
Jan 22, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
336 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
