Question about Canon PIXMA MP460 All-In-One InkJet Printer
Canon pixma mp460 code error 6000
I have had no problems at all untill now.. and its say error code 6000, there is no paper jammed in it all it says that there is a error code 6000Same problem with my Canon MP 460. It stopped right in the middle of printing a page and the 6000 error code appeared and the printer is stuck there.
  • caalvin Jan 17, 2009
    I uninstalled the printer and driver and reinstalled everything: same problem. I have looked for obstructions everywhere but all seems OK. I liked this printer because the colors in the photos were excellent. Please help!
    Sergeant:
  • 221 Answers
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3.The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
Posted on Jan 17, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Error 6000 is usually caused by a bad device drivers, missing system files, wrong system settings or a corrupted registry file. First, reboot your computer to insure the error is not temporary. If the error returns you will need to run a registry scan to check for registry errors & other system problems. 89% of the time this will fix the cause of the error.
Thanks
Rylee
  • 916 Answers
Disconnect the power cord
Unhinge the back access panel of the printer.
Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
Close the back access panel. Make sure that it latches into place andlooks the same way that it did before you opened it.
Find the front or top access panel. This is the panel you would lift to change ink.Open this access panel.Look for paper that may be jammed in this area of the printer.
Remove any paper you find jammed here. When pulling from the frontthere will be resistance from the paper feeder. Pull slowly or thepaper will rip and create a more stressful problem.
Close the front access panel. Make sure that it falls or latches backin place. It should look the same way that it did before you opened it.
Plug the printer’s power cord into the wall outlet, and attempt to print again.
    Brigadier General:
  • Canon Master
  • 3,614 Answers
If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Posted on Jan 16, 2009
    Genius:
  • 1,199 Answers
Remove paper reinstall the software for the device restart the PC and try again!
    Sergeant:
    Scholar:
  • 199 Answers
This the error code for stuck sensor.remove the paper.turn printer off for a while remove drivers and reinstall again to solve the problem.
What is service code 6000?
Hello Richard Miller
The error that you have, it means that your printer has a paper jam, this is the error appears in you computer, may be in the printer have the next error number. P3 followed E3
If you are writing this review, it is because they believe you have a paper jam, if they have seen and removed yourself.
Principally printers and Canon, in many cases the system detects a paper jam, but is not exactly a paper is causing the problem, in many cases can be any object that has entered and is obstructing the passage of the pages.
My first recommendation is to look carefully where they enter the pages on your printer, if necessary use some lighting for better viewing, you might find something there.
If after all get nothing related, follow the steps below to solve your problem. http://www.en.rellenadodecartuchos.com/2015/04/delete-service-error-6000-or-p3-fallowed-e3-canon-pixma-mp240-printer.html
Even then, you can not solve the problem, I recommend the following way, which is to eliminate jam Canon inbox.
service-code-6000-xnnjabddbe1z3hwtjta3ekn0-4-2.jpg Remove error 6000 printer Canon PIXMA MG2410 en Rellenado
To be honest most of the time are other elements that influence paper jams, which can not be determined on the Canon printers.
Nov 20, 2015 | Canon PIXMA Office Equipment & Supplies
Service error 6000
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP460 Paper Jam
this is only a possible solution.make sure the paper is between 17  to 24 pounds thick.i once had a jamming problem and it turned out to be the printer which canon replaced under warranty.but in the process i learned paper thickness can make a difference. i was recommended 20 pounds by a staples employee.i hope this helps you.
Apr 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP460 "np paper"
Canon PIXMA MP460 error code 5010
Sep 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
for the guest
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
125 people viewed this question
old marine
old marine
