Question about Yamaha HTR-5550 Receiver
Yamaha 5550 will not power up
I have a yamaha 5550 receiver that will no poer up. I have checked the fuses they are good and are getting power.
  • 3 Answers
Replace power supply
Posted on Jan 16, 2009
Yamaha RV3300 receiver that will not turn on
Sounds like a relay (there to keep the unit from getting "fried" when there is a malfunction). You need to check that out to get started....
This should help..
https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_rx-v3300_dsp-az2_service_en.pdf
You'll need to register, but it is free to do so!
Good luck! Login HiFi Engine
Sep 27, 2017 | Yamaha Audio Players & Recorders
When I hit power button nothing lights up but I hear the subwoofer power on but still no sound. It's as if it wasn't getting power.
Try disconnecting everything from the back of the system and unplugging it form the wall for a couple of minutes. Plug it back in and try poering it on. You may google search "diagnostics boot" or "error boot" with you model number and see what comes up. There is a fuce inside you could check, usually to the back right on Yamaha receivers. This doesn't sound likely due to your subwoofer sound though....maybe.
I bought about 70 receivers that were last years models from Yamaha, Denon, Sony Bravia, etc. Most worked but some required fixing. Some where easy as fuses, blown capacitors (visually), then some are still in my storage LOL. I hope this helps. By the wy, you can always purchase a repair/diagnostics manual that repair shops use with diagrams and trouble shooting tips for your particular model.
GOoD luck
Jun 30, 2010 | Yamaha RX-V520
One channel does not receive signal as shown by the led.oudtput stage is perfect the amp is a Yamaha P4500 poer amp
Try reverse connecting the channels, in order to locate where is the problem; at the cables or at the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha htr 5550 stereo receiver blank display. It
I would suggest a quick resoldering of the flatcable connectors, both on the display board as well as on the main board. That should fix the problem.
Oct 20, 2009 | Audio Players & Recorders
Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
Sep 08, 2009 | Yamaha HTR-5890 Receiver
HTR-5550 will shut-off after an hour of operation
Hi Guillot
I would be checking about the regulator and power output stages for dry solder joints. With the progressive heating of the unit from operation, failing solder joints may be causing a condition to occur that operates the protection circuit. Careful inspection under good light is required. You may find soldering around outputs, drivers and other devices mounted on heat sinks or other devices that run hot to have circular fractures in the solder about the lead to be commonly responsible for the problems you are facing., if you have a soldering suitable iron, and the time and patience, go for it. I have included a link to a soldering guide here.
Good luck, thanks for using FixYa, and a rating of FixYa would be great for my time to address your problem. Cheers
regards
Graeme
Mar 16, 2008 | Yamaha HTR-5550 Receiver
HTR-5550 will not stay on.
jerry ...
question??? before you stored the unit, was it working fine?
are you using the same sets of speakers like before?
Mar 15, 2008 | Yamaha HTR-5550 Receiver
Will not power in
IT IS THE POWER SUPPLY HAS TO BE CHANGED ONLY THING IT COS AS MUCH TO FIX AS TO BUY A NEW UNIT AS I WAS TOLD UNLESS U KNOW WHER I CAN FID A POER SUPPLY FOR THAT MODEL
Nov 16, 2007 | Yamaha HTR-5560 Receiver
Yamaha HTR-5550 Receiver Logo
283 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
