Question about E-Machines eMachines Desktop PC
Emachine Won't power up
I was told me emachine needed a internal power supply...I bought one, and I think I have eveything plugged in right, but the power supply has a SATA plug and I don't see where it would plug into I would love to see a wiring diagram for myself...And it still won't power up...any Ideas??
  • justinel6477 Jan 16, 2009
    The first time I paid someone at a computer store to fix it for me, he is the one who said it went out before, about 2 yrs ago....but I have been "tinkering" with this one since and had to replace my CD burner, and It looked to be kind of a simple task to change it out....Well it "died" again, and so I bought a brand new power supply from CompUSA...Bought the exact one that was in it...and changed it out but I had undid some of the plugs prior to getting it, and couldn't remember unplugging the SATA plug...and it didn't power up, So I was afraid I may have "forgotten" where to plug it...
    lol No there wasn't...Nothing...
    You are not going to believe this...The outlet I was using wasn't working!! As an after thought I changed outlets and plugged into a different one...Viola!! It is fixed!!
    THANK YOU so much! I will save the site...I have some work to do on a laptop...Might need some help...lol
    Novelist:
  • 180 Answers
Just because it has a SATA plug doesn't mean you'll need it- especially if your machines a few years old. If your hard drive doesn't have the sata connections, then you probably won't use it.
As to why it still won't power up- how did you determine your last power supply was dead? Did you happen to switch out with a known good one? There is the slim chance the new one is ****- bad out of box. Any of your friends have a power supply tester or can you buy one? They are cheap- about $20. A good investment if you help others out as well.
Posted on Jan 16, 2009
  • Bill Speer
    Bill Speer Jan 16, 2009
    When you attempt to power it up, does the fan in the power supply spin? Any sign of activity at all?
  • Bill Speer
    HA! An obvious troubleshooting method I failed to mention. My thanks to you for reminding me of the obvious.
Emachine won't power on??
from the video the only think i can think of is that some computers have a little red switch that changes from an american standard voltage to european standard make sure that switch is turned to 120v(located in the back of the computer with mouse and keyboard connectors). secondly the other solution if that didn't work the power supply were the plug is connected into for the computer is propably not connected to the motherboard. to do that their is a connector on the power supply that should say P1 that connects to the motherboard. if all that fails have some own or yourself plug something in to the outlet in which you use for your computer to see if the outlet is at fault. If all else fails get a new power supply and have yourself or a computer technician or have a pro technician in PC maintence look at your computer or just buy a new computer.
*hope this was of use to you and sorry for the spelling mistakes*
Mar 18, 2013 | Computers & Internet
Getting sound with new emachine!!! I am new to all this and for the life of me cant get any sound bought lead for connection but where or what do I do with it?
HI,
GETTING SOUND WITH EMACHINE,IT IS PROBLEM WITH WIRES INSIDE MACHINE TOUCHING THE CPU FAN AND ONE MORE PROBLEM WILL BE,INSIDE THE SMPS (SWITH MODE POWER SUPPLY) HAS INTERNAL COOLING FAN,WHEN ITS ON SOME TIME THE COOLING FAN INSIDE SMPS TOUCHES BODY.DUE THE RELEASE OF FAN FIXING AREA.
TNKS
RABBANEES
Oct 27, 2009 | E-Machines eMachines Monitor E15T4
When installing the power supply on the emachine t4510, where do all of the plugs need to be placed. i got one that didn't have a power supply. i picked up a power supply and i'm not sure if i pluged it in...
there is a big white connecter in smps (powercable }it connect in board. there is power cable need for optical drive/ hard disk/ from smps we supply in only bord / hdd/optical/ we connect cpu fan from bord.
Oct 14, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I have emachine w3400 not powering . plz help
I found this right on this website, hope it works!
As for the fans, make sure your connections are tight and in the proper sockets.
Jul 09, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
Emcahine Monitor sound is low
check the speak rail, the emachine speakers need a amplifier, there should have a power supply plug, that you need to plug it in.
if not, call up the place you brought the machine and ask them, where is the amplifier plug.
Dec 10, 2008 | E-Machines eMachines Monitor E15T4
Emachine t3958
First check to see if a drive died. Unplug all the drive Floppy, hard and dvd or burns. I have come across many time that a drive will die and keep motherboard from booting. Being that you say you get a green light on the motherboard shows that the power suppy is providing some power. But for some reason the internal self test is faulting the power suppy. I have not come cross any bad power supplies killing a motherboard. But I have come across power supplies killing drives. The power switch is a normal open switch so the only time you be able test continuity on it is if you hold the switch in, or the closed position.
Apr 03, 2008 | E-Machines eMachines Desktop PC
My computer
ok " here is what i would do , un plug the power to hardware one by one, and restart computer, after each unplug
think youll find the one thats causeing the problem
Jan 21, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
108 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
