Back to:
Tags:
Electrolux 18 in. ESL424 Built-in Dishwasher
Dishwasher fault
posted by bluebluetoe on Jun 17, 2007
hi, could anyone please help my dishwasher fills the bottom with water but it dosen1t start the rinse cycle any help would be great
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 18, 2007
Not Rated (0)
24 seven
Rank:Wiz Wiz
Rating: 82%, 1174 votes
If you have tried to run any cycle and still end up with this problem, then most likely a failed timer unit. The next step is for the water switch to enact the next step which is to start the timer.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dishwasher fault:
I don't want to Accept this solution
Can you Help with these Dishwashers problems?
Dishwashers
I have a hobart lx 18 commercial dishwasher that needs a...
Dishwashers
My kitchenaid dishwasher heating element looks as if a...
Dishwashers
5 year old Maytag did not release soap nor did it drain. ...
Electrolux 18 in. ESL424 Built-in...
hi there is no water going itto my dishwasher do you think...
at the end of the cycle there is at least an inch of water...
Loading problems.
Repair Service
Find Dishwasher Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
