Question about Intertherm P3RA-048K Air Conditioner
Get a screeching sound from unit when heater is on.
When i turn the heater on i hear a screeching sound coming from the unit outside by the house but can't tell if it is coming from the fan or what/where the noise is coming from.
    Problem Solver:
  • 16 Answers
Chances are it is the outdoor fan motor. Does it squal when you run the A/C? If not it could be the reversing valve solonoid.
Posted on Jan 17, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Braeburn heater not heating
-You're talking about house heater Not car right...?
-If so. Is it a gas heater...? You better ask a technician to do for you
because Not body can sell you a part.
Mai
Apr 13, 2013 | Cars & Trucks
Even though the outside temp is above 35 degrees my unit still runs as if it is on emergency heat because the outside fan does not come on and the house is really hot!
SOunds like we have some control problems--
First explain what you mean by 'Emergency Heat'-- (That is a new expression to me..)
And what is the 'Outside Fan' yo are speaking about?
And for basics-- are we talking about and electric heater-- a Gas heater, or what?
Is this a furnace-- or a wall or window unit-- Tell us more-- and we'll get to the next steps..
I am wondering why the house is so HOT-- Where is the thermostat?
Mack B
Jan 15, 2011 | Heating & Cooling
Atwood 10 gallon H2O heater- replaced thermal couple and electrode spark and sensor but heater comes on with switch, heats water for 10 to 15 mins then burner goes out. Can hear a couple of switching...
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Aug 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
My heat willnot come on all i here is humm in the unit under the house and nothing inthe outside unit it is a "Googman-ARUF02400A1"
Ok, If you don't have a heat pump, you should not be hearing anything from the outside unit. I assume you have electric heat. I feel strongly that you have a bad fan motor capacitor. This is what sends a jolt of power to start the fan motor. Good luck and have a great day.
Oct 18, 2009 | Goodman Heating & Cooling
Outside fan does not spin and a loud screeching sound coming from
Hey there, sounds like the bearings seized in your fan motor. You need to replace the fan motor. If the compressor runs without the fan, th pressures build up and if they reach an extreme point, the compressor will bypass internally, creating a loud sound as the high pressure is released to the low pressure side. I would turn the thermostat on and stand by the outdoor unit as it start. Leave the disconnect on the wall readily available so you can quickly turn it off. If the compressor sounds ok when it starts up and runs for a couple seconds, turn it off right away and replace the fan motor and you should be good to go. If the compressor sounds bad or real noisy immediately at start up, the fan motor not working killed your compreesor. You would need a motor and compressor, might as well replace the unit at this point if you are paying to have it done. Let me know if you need anything else
seth
Jul 03, 2009 | Carrier Heating & Cooling
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
The Exterior Units does not turn on.
It sounds like the outdoor unit is tripping on high pressure. This can be caused be a dirty outdoor coil. It can take hours for the unit to reset and try again. a loose or damaged control wire can also cause intermittent power loss as you have described. With that said I suggest that you call a technician to check it out.
Jun 12, 2008 | Goodman GMS90703BXA Heater
Intertherm P3RA-048K Air Conditioner Logo
153 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
