Question about Aureal MTC Vortex Advantage PCI Sound Card
Headset/mic not being detected...
Ok, so i just got a late christmas present (from sweeden) and it is a headset, a really good one! buuut, no drivers, and its plugs are the little pink and green plugs, not usb, and my computer dosent recognise them, restarting dosent help.
  • 1 more comment
  • battle_bit Jan 16, 2009
    Oh, i don't know what sound car i have, i think it is just an onboard one.
    card*
    Strange.... I plug them into the right holes.... but nothing happens... not even the static you usuialy hear.
  • 827 Answers
You just put the green one into the green hole, if there is one. It is the plug for the speakers/headphones. And the pink one goes into the red hole usually, that's for the microphone.
If you have sound coming from your computer at all, then the drivers necessary to use your headset are already installed.
If you are going to use Messenger or Skype, just go to the audio setting and try the different devices from the drop down list until you select the correct one. You'll know it's the correct one, because you'll see movement in the audio bar in settings.
Hope this helps!
Chris (ziraffa)
Posted on Jan 16, 2009
  • 1 more comment
  • chris grams
    chris grams Jan 16, 2009
    You don't need drivers.. your computer doesn't 'recognise' them because they aren't a 'device' and don't require a driver..
    They just require a suitable program with which they can be used, like Skype/Messenger/AIM etc
    Thought I'd better just add that..
  • chris grams
    What's your computer? and operating system?
    You may need to unmute the mic and turn up something in Vome Control/Mixer etc..
  • chris grams
    It's possible you are plugging into the onboard audio plugs instead of the sound card, or vice versa?
Why does the mic on my headset not work properly?
play whit the wire off the headset.maybe the wire is not good.
also check the plug in
May 24, 2014 | Plantronics Gamecom 780 Usb Headset
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Logitech G930 Echo problem
Check the device manager for duplicate devices and make sure that the on board devices are disabled
Dec 09, 2013 | Logitech G930 Wireless Headset
Dell 5050 laptop headset mic is not working
Do you have the latest drivers? If you're not sure, go http://www.dell.com/support/drivers/in/en/indhs1/Product/inspiron-15-intel-n5050 and install at least the audiodrivers.
If this doesn't work, go to control panel>hardware&sound>manage audio devices>recording, and see if your headset microphone is listed in there. Choose as default device if it is.
Aug 27, 2012 | Computers & Internet
Logitech Headset m/n A00008 will not do voice-over video editing
Wisdom_share
To solve your headset audio problem you would need to let the PC install the your device driver. Once that is finished right click on the speaker icon to the right bottom and select the Playback Devices option. You should see your device headset icon right click on it and choose Set as Default Device and that you would guaranteed to you work for you. Good luck to you!
Apr 10, 2010 | Logitech ClearChat Pro USB Headset
How to configure a headset with mic?
Headset will have two pins .plug the pin initially
The green pin should be plugged to speaker and the red pin to the mic.
In the volume button select the advance properties and increase the volume of mic .sometimes it may be in mute if so un mute it.
Ensure proper drivers are installed and mic is detected i the system.This can be seen from the sound devices option in control panel .
To check whether mic is working try to record using the sound recorder which is present in system
Mar 04, 2010 | Computers & Internet
I just bought a Logitech Clearchat Stereo Headset and am running Windows XP. The mic is not recognizing while plugged into the front or back plugs. Is there something wrong with my soundcard?
You should go to your Device Manager in the "System" category of the Control panel and see if indeed the driver for your mic is present. It will be listed under "Sound, Video and Gaming devices."
Sep 22, 2009 | Logitech ClearChat Stereo Headset Headset
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Microphone can be detected but doesnt work
Go to start then control pannel then sounds and audio devices. Then in in the volume tab select advanced in the device volume section. When the mixer comes up go to options then properties select the recording option a recording mixer will come up make sure to check the microphone box. Raise the level in the ixer and you should be golden. If you want to hear the mic select playback mixer and raise the mic level. Hope this helps. : ]
Dec 09, 2007 | ASUS P5RD1-VM Motherboard
Aureal MTC Vortex Advantage PCI Sound Card Logo
75 people viewed this question
Top Aureal Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
john h
Paul Chapman
Paul Chapman
Are you an Aureal Computer and Internet Expert? Answer questions, earn points and help others
