Question about Waring Pro WC1000 Coffee Maker
Carafe lid Hi, just purchased a Waring Pro pourover coffee maker. I can't figure out how to get the lid up on the carafe to wash or run water in it. Thanks Rita Montgomery
This puzzled us as well when we purchased ours. If you look at the top of the handle there are two little pieces that stick out on both sides. Lift these straight up and the lid will pop off.
Tina G
Posted on Feb 11, 2009
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There...
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Jul 29, 2010 | Cuisinart DCC-1200 Coffee Maker
If I put 6 cups of water in when it is done there is left only 4
The good news is there is nothing wrong with your coffee maker!
With any coffee maker that heats up the water, you're going to lose some of that water to the heating process (steam, etc.). You also don't get every bit of water out of the machine.
So that's why you need to look at the water reservoir level indications instead of using the graduations marked on the glass coffee carafe.
Typically, once you've figured out how you coffee maker works, I'd just "add" 2 more cups of water in the glass coffee carafe to get the amount of cups you want to brew.
I know my coffee maker is pretty close to exactly 2 cups shy of whatever I put in the glass carafe that I pour into my coffee maker. That's when I noticed the markings inside the water reservoir that didn't match the coffee pot. It was always 2 cups shy, so I just put 8 cups of water (using the carafe) to get 6 cups in the morning.
So I suggest you just you make these small adjustments to your water measuring and you'll get the right amount of brewed coffee out of your machine!
Hope you find this Very Helpful and best regards!
Sep 23, 2009 | Cuisinart DCC-1200 Coffee Maker
The cuisinart repeated;y clogs and sprays water
The two most common reasons for overflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Not brewing. Add water and coffee, switch to the brew selection and the water/coffee does not flow. The machine heat ups and starts processing noise.
Make sure the lid is on the carafe.
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 30, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My coffee maker, Cuisinart dcc 1400 only boils water, does not make coffee. It is one week old. I have a water filter in the plastic filter holder filled with coffee.
Aug 10, 2009 | Cuisinart Coffee Makers & Espresso...
I clean it everynight but it still leaks coffee grins and coffee all over the place...this is the second coffee maker of its kind that i have had and they both have done the same thing. This only happens...
Jul 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Lid on carafe
Sadly, I have about 10 people who have this coffee maker. It is a wonderful little coffee maker and is very delicate.
the worst problem all the people here say is the lid leaks like a waterfall or it leaks by dripping non stop while pouring.
I had to call Bunn, who made this machine, and they have yet to figure out a solution to this problem other than having people who own this machine buy a whole new carafe with new seals.
You might try your local applianace repair store. Sometimes their engineers are smart guys who knows exactly what seals will work or where to get the parts you need better than the actual manufacter.
May 12, 2008 | Bunn BT10B Coffee Maker
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000 Coffee Maker Logo
91 people viewed this question
Top Waring Coffee Makers & Espresso Machines Experts
Hjalmer Lamminen
Hjalmer Lamminen
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
