Question about Toshiba 50H81 50" Rear Projection Television
Colors will not converge on toshiba projection 50H13.
I know how to converge my TV set. The green on the screen seems to be a set color and it is distorted. It bows upwards which affects the Red and Blue. The middle and upward portion of the screen seem to work together but the rest is like a wave or bubble and the colors will not come together. When I do the auto convergence it gives me an "Convergence Error"
    Problem Solver:
  • 14 Answers
Hello, looking over what wrote, I have had a similar experience. Lets start by checking the location of your speakers, and subwoofer. The magnetic field from speakers can pull the color on your T.V. this would cause a rounded line. Also if you have cables going from your Cable box to a reciever you don't want to place these cables to close to the speakers either. Also do you have any equipment setting on top of your T.V. with the cables dropping down the back, can cause this as well. I hope this helps and we look forward to hearing back from you if this dosen't solve your problem. Also check for any magnets laying around the or on the TV I have kids and they set a referator magnet on mine and it pulled the color to the corner. Thank You and have a good evening
Posted on Jan 16, 2009
    Sergeant:
  • 233 Answers
Your TV has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go. If you need to order a resistor or two,
http://servicemanuals.vstore.ca/index.php/cName/convergence-resistors
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at manualuniverse.com
Hope that helps!
My colors are off on the tv seems to be really green. The red seems to flicker a little and the the looks like there is dirt all over the inside of bulb. Do I need to replace bulbs or try something else
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 21, 2011 | Philips 6P5430W 54" Rear Projection...
My picture is O.K., but the colors are not right. Too much green. I can't seem to find an adjustment that corrects the problem.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 27, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Green is above other colors on convergence
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
My colors are not blending correctly anymore. My green is giving me a double picture. I have tried to blend them on the front and back but not luck. I need help
  • Screen looks 3D
69189a5.pngCONVERGENCE SOLUTION
Jan 11, 2011 | Hitachi 50DX01B 50" Rear Projection...
Words ars doubled and arching, green and purple across parts of the screen, picture blurred
  • Screen looks 3D
69189a5.pngSOLUTION
Dec 26, 2010 | Toshiba 53HX71 53" Rear Projection...
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
The picture on my TV has started to "shadow" or double on the sides of the screen and seems to be slowly working its way across the entire screen. The color is also getting goofy. My set is 7 years old.
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 12, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Green and blue shadows on the screen
•Screen looks 3D
Jul 30, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Picture appears to be 3d
•Screen looks 3D
Jun 25, 2010 | Toshiba 43A10 43" Rear Projection...
Colours are out
•Screen looks 3D
Mar 10, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
