Question about HP DeskJet 1600C InkJet Printer
How do I print on both sides of my paper
I am trying to create a small booklet with text on all sides of the pages. I have never done this before and any help or advive would be appreciated.
  • 624 Answers
On printers without a duplexer (a device that flips the paper to allow printing on both sides) you will have to print the first side, manually flip and print the second side. If you're using MS Word or MS Publisher you can easily configure the program to organize the pages for you: Start a new, blank document. -Click File, Page Setup then click the Margins tab. -In the Multiple pages section select Book fold. -Set your document to landscape orientation if it is not already. -In the Inside and Outside boxes, type or select the amount of space you want for your margins. -In the Sheets per booklet list select the number of pages you want to include in a single booklet. If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets. -When you get ready to print make sure you check the manual duplex box (should be in the first dialog box that appears when you click on File, Print). Word will print the first page, and then prompt you to take the pages that just printed and load them into the input tray of your printer. The trick is to learn how to orient the pages correctly for your printer. Good luck.
Posted on Jun 17, 2007
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
Making a booklet out of a multi-page PageMaker file
many questions, the answer should be yes and all is in the driver settings but it all depends on if you have the correct driver installed and configured correctly for your copier and if your finisher is a booklet finisher. if you have every thing laid out in page maker correctly and the driver is setup correctly then it should do just fine.
Apr 14, 2010 | Canon imageRUNNER C3170U Color Copier
Problems printing a booklet
What size paper are you printing on? Reset the side margin to make narrow and see if that helps.
Sep 23, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Booklet printing pages in wrong order.
I believe this is going to be a software issue. Do a print preview of the booklet first to see if they are showing up in the right order. If they are, then it is a printer issues and I really can't help you there, but it they aren't then you know it might be a software issue. Check you formatting on the document before you trying printing it again.
Jun 30, 2009 | Epson Stylus Photo R300 InkJet Printer
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
InDesign Cs - create A5 booklets for printing on A4 paper
there's the function PRINT BOOKLET under the file menu
Nov 07, 2008 | Computers & Internet
Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Apr 11, 2008 | Xerox Office Equipment & Supplies
Printing position of a picture
heyo Chuckie,
Really depends on your printer. I am assuming you are using Word. When looking at your documents, go to FILE, PRINT, click on PROPERTIES and then LAYOUT tab. THere is BORDERLESS printing. If you have a laser printer it may not have a problem with this, if you have an inkjet, there are paper rollers in the print that need to hold the paper while printing. As a last resort, I would make a PDF of the doc and swing over to Kinkos or a printing shop and print it off there.
Good Luck.
Wayne
Dec 31, 2007 | Microsoft Office Professional 2007 Full...
HP DeskJet 1600C InkJet Printer Logo
351 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
