Problems with the built in wireless on my acer extensa 5220
I bought a acer extensa 5220 it had no os on it I put windows vista on it,but the built in wireless does not work,so I use a usb wireless adapter.Is there a driver I need to install?
  • 5 more comments
  • Mark Benson
    Mark Benson Jan 16, 2009
    link is dead,says it cannot be found
  • Mark Benson
    ok I got the files unzipped and there are 2 folders 1 for apps and 1 for drivers.In drivers I would install the 32 bit that is what I have.
    There is also something called Iprodifx install shield,do I need to install that?
    In apps there is Iproinst do I need to install that?
    also in apps there is a folder called I pro data with a bunch of programs you can install do I need to do that?
    Thanks for the help
  • Mark Benson
    Would I need to uninstall the software for my usb wireless stick before my built in wireless will work after I run the DPINST32EXT,because there is a choice in the manager for the usb wireless stick that says use this ativa utility to control my wireless connections.
    I do thank you for all your help.
  • Mark Benson
    I am sure you know what I am talking about,I just installed that driver,now that is what should make the built in wireless that my computer is suppose to have work.as I said when I bought this laptop it had no operating system on it.Again I really thank you for your help.
  • Mark Benson
    I did install the intel drivers and when I push the switch over on my laptop to see if it will turn green and pick up a wireless signal it did nothing,so would it do any good to remove the usb wireless software,or is there something else going on with my laptop that needs attention.
  • Mark Benson
    Ok,I do see 2 connections,both are netgear 101 and netgear 101 3
    Here is what is listed in the device manager under network adapters ativa wireless G usb network adapter and Broadcom Netlink (TM) Gigabit Ethernet.
  • Mark Benson
    yes it does have a light but it never lights up.ok thanks
  • 98 Answers
Yes, you will need drivers for your wireless card.
You can download them here.
Posted on Jan 15, 2009
  • 4 more comments
  • Nikola Malesevic
    Nikola Malesevic Jan 16, 2009
    Sorry, my mistake. Check this link.
    I am sorry for the inconvenience.
  • Nikola Malesevic
    It seems Fixya does not allow inserting ftp addresses.
    Here is the address, copy it to your browser:
    ftp://ftp.work.acer-euro.com/notebook/extensa_5220/vista/Drivers/Wireless_Intel_4965_3945_v11_1_0_86_vista.zip
  • Nikola Malesevic
    Just go to folder Intel\Drivers and run DPInst32.exe.
  • Nikola Malesevic
    That depends on the compatibility of the drivers. Most likely everything will be just fine without removing the other drivers, but in some cases, there can be problems. You should try and install these Intel drivers, and see what happens. If you get to separate Wireless Network Connections, the problem is solved. If you get only one, try removing the drivers for your USB Wireless.
    On the other hand, if you do not need two wireless connections at the same time, remove USB wireless adapter, remove drivers you have installed, and install new ones.
  • Nikola Malesevic
    Please go to Network Connections in Control Panel. How many connections do you see?
    Can you list them here?
    Can you also open Device Manager and see if the wireless device is listed there?
  • Nikola Malesevic
    It appears that the installation of the drivers for your onboard wireless adapter has failed. Try to remove existing wireless drivers used by your USB wireless adapter, as well as the ones you installed recently for your onboard adapter, if they exist in Add/Remove Programs applet. Then try to install Intel Wireless drivers again.
    On the other hand, problem might be with your on/off switch. If you have LED indicator for your wireless network on laptop, and it does not light up when you press the switch, it might point that there is a hardware failure on onboard wireless device. In this case, I recommend going to the shop and asking for a refund, or replacement laptop.
    LED must light up (if it exists) if you turn on the wireless device on your laptop, regardless of existence of the drivers.
HOW TO CONNECT A HP MONITOR TO AN ACER EXTENSA 5220 LAPTOP
Plug the VGA lead from the monitor into the laptop and power the screen up then the laptop. Select external screen on your laptop.
Sep 18, 2014 | Acer Extensa Computers & Internet
Extensa 4630z Bluetooth draivars
you can download the drivers from the links below for the window you required
For Windows Vista http://global-download.acer.com/GDFiles/Driver/Bluetooth/Bluetooth_Broadcom_v.6.0.1.6400_Vistax86x64.zip?acerid=633639777854754656&Step1=Notebook&Step2=Extensa&Step3=Extensa%204630Z&OS=V10&LC=en&BC=Acer&SC=EMEA_1
For Windows XP http://global-download.acer.com/GDFiles/Driver/Bluetooth/Bluetooth_Broadcom_5.1.0.4500_XPx86_A.zip?acerid=633830645935938902&Step1=Notebook&Step2=Extensa&Step3=Extensa%204630Z&OS=X02&LC=en&BC=Acer&SC=EMEA_1
For Windows 7 http://global-download.acer.com/GDFiles/Driver/Bluetooth/Bluetooth_Broadcom_6.2.1.500_W7x86W7x64_A.zip?acerid=634025113718291872&Step1=Notebook&Step2=Extensa&Step3=Extensa%204630Z&OS=702&LC=en&BC=Acer&SC=EMEA_1
Regards, Bilal
Jan 11, 2011 | Acer Computers & Internet
How can i factory set my acer extensa 5220
To restore your laptop you need the restore cd/dvd that came with your laptop when you bought it.
Please be adviced that restoring your laptop will cause you to lose all your data. Backup any data you would like to keep, to an externad drive or usb.
To restore your laptop do the following:
Insert the restore cd in your cd/dvd drive and restart your computer.
When you see the message "Press any key to boot from cd" press enter.
Then follow the on screen instructions to restore your laptop.
Regards,
nicolasiac
Mar 03, 2010 | Computers & Internet
I want free driver for acer extensa 4230 vista
I need product key for extensa 4230 windows vista , microsoft 2007
Mar 01, 2009 | Acer Extensa 4620 Notebook
Acer extensa 5620 driver
help me pls to fined wifi driver of extansa 5220
Feb 01, 2009 | Acer Extensa 5620-6119 Notebook
Change computer from French to English and back on Acer Extensa 5220
i think it can only be changed by switching to an english windows version or buy a universal windows vista version.\
sorry i can't be more specific.
Aug 29, 2008 | Computers & Internet
Laptop speakers
you shouldn't have a problem, Vista uses Realtek high definition audio, assuming this is the sound make you use you need to install the normal Realtek audio driver, see below:-
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false
Aug 14, 2008 | Acer Extensa 503T Notebook
Want to swich back to windows vista.
You'll need to get the OS cd or use the internet wisely & get one off there. You can make a boot cd that will help.
Get bac @ me!
KJ
Apr 22, 2008 | Computers & Internet
Computers & Internet Logo
1,471 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
