Question about Hotpoint RGB745 Gas Kitchen Range
Burners work,Broiler works but oven does not preheat
Went to preheat oven and it never ignighted. The oven light lit up, but never got hot. We do not smell gas. Model# RGB745WEA2WW
  • 5,911 Answers
If everything works on your range, but the oven, the most likely culprit is the igniter for the BAKE manifold. What is confusing me, though is the statement in your question where you say the "oven will light up, but never get hot". Yet, you say the oven does not ignite. Can you clarify this? In some ovens the BAKE and BROIL manifolds BOTH light when preheating, to reduce the warm up time. Once the desired temperature is reached the manifold not in use, will shut off.
In any case, on a gas range, the burners for the BAKE and BROIL manifolds use an electric glow bar type igniter. There's a separate igniter for EACH burner. When you make a bake or broil selection on your oven control, the respective igniter begins to glow. After the igniter reaches a certain current potential, the gas safety valve is opened, gas flows to the manifold, and voila! You have ignition. It can take as long as 90 seconds for the burner to ignite. What can happen over time, is the igniter becomes weak or fails. If the igniter becomes weak, it will still glow, but it never reaches the desired current potential to open the gas safety valve. The result: you end up with an igniter glowing with no ignition. And, if you're like me, you're left scratching your head wondering why the thing isn't working when it "looks" like it is. You can easily tell if the igniter is working by opening your oven door and selecting bake. Watch the oven pan in the bottom of the oven. You should see an orange glow coming from under it. It here's no glow at all, the igniter has probably failed. If there IS a glow, a current reading will tell if it's within tolerance. The following link explains more on these igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter is a common fail item as it gets used more frequently than the broil function. On your range both igniters are interchangeable. You can purchase replacements on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. The part number is WB2X9154. Shop all three sites for the best price.
I hope this helps you. If my assessment of your symptoms is wrong, or if you need further assistance, please let me know.
Posted on Jan 16, 2009
  • David Nichols
    David Nichols Jul 08, 2014
    what if the above is true for everything except, I do smell gas. Burners work, broiler works, oven has an orange glow but does not ignite the gas, BUT I DO SMELL GAS...when it is trying to preheat.
    President:
  • 1,214 Answers
You won't smell gas because there is a safety system that prevents the main gas valve from opening until a pilot confirm signal is sent.
The sequence of operation is -
1) Oven control is turned on
2) Gas flow occurs through the main oven control to the pilot burner and electronic ignition starts
3) Ionization sensor near the pilot senses if there is a pilot
4) If there is a pilot, open the main gas valve
5) If not pilot, shut down pilot gas flow
I suspect the igniter is bad, but it could be the main controller board. You can go to Sears Parts Direct website, tyepe in your model number, and get an exploded view and parts listing for your unit.
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Oven & Broiler quit working on same day.
Yes, I think you have the answer. If you have the knowledge, check the electrical supply side, fuse etc. Check out your user manual in the fault finding section. The oven has a thermo switch that prevents the gas opening if theres no ignition.
Apr 17, 2015 | Kitchen Ranges
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven Wont Preheat
does the bottom element get hot? could be a bad heating element.
Feb 01, 2009 | GE Kitchen Ranges
WHIRLPOOL SUPER CAPACITY 465 SF385PEGZ3 NO OVEN/BROILER
sounds like an issue with the spark module, altough that module tends to be really relliable.i would try removing pawer to te unit. checking the outlet for proper grounding,and replugging unit see if that works for you
Oct 25, 2008 | Whirlpool GS460 Gas Kitchen Range
Oven Not Working
see if your broiler works if it does replace the bootom ignighter even though it glowes does not mean its working right it has to pull a ceartain amount of amps for the safty valve to open if the broiler doesnt light then the safty valve needs replacing and reply for futher info
Aug 16, 2008 | Whirlpool GS460 Gas Kitchen Range
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven takes a long time to preheat
Before we go into diagnosis mode, call the customer service # in the owners manual and complain about the problem.  They usually will make a concession when it is this close to the warranty period.  Let me know what you find out.
Oct 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
1,469 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
