Question about Fedders Y Chassis A6Y18F7A Air Conditioner
Water is not dripping from window A/C unit, air is cold but damp
Water used to drip from the outside of our Fedders unit properly, but not for past 2 summers. Also, the unit cools the air well, but the room feels damp, humid. It is as if the air is being cooled but just not quite enough for the condensation temperature to be reached (ie, 100% rel.humidity), and, thus, condensation does not occur. Either that or somehow the condensed water is being reabsorbed by the cooled air. The unit is tilted to the outside properly (about 2-degrees down to outside), and there is no water running into the room. Any suggestions? Thanks.
    Novelist:
  • 114 Answers
HELLO .. HOPEFULLY YOUR UNIT SLIDES OUT OF THE A/C HOUSING, IF IT DOES REMOVE IT. (THERE MAY BE A FEW SCREWS HOLDING IT IN PLACE USUALLY BEHIND THE FRONT GRILL) PUT DOWN SOME OLD RUGS FIRST AND HAVE SOMEONE HELP YOU SLIDE IT OUT. GET OT THE GARDEN HOSE AND SPRAY NOZZLE. PROP UP THE FRONT OF THE UNIT SO IT DRAINS TO THE REAR. BOTH THE EVAPORATOR COIL AND CONDENSER COILS SHOULD BE CLEAN. YOU WILL NOT SEE DIRT ON THE OUT-SIDE OF THE COIL ... IT WILL BE ON THE INSIDE HIDDEN BY THE CONDENSER FAN BLADE. BE VERY CAREFUL NOT TO BEND THE FAN BLADE WHILE INSPECTING OR WASHING. BE EXTREAMLY CAREFUL TO COVER THE MOTOR AND ELECTRICAL CONTROL BOX WITH PLASTIC BAGS TO ENSURE ALL ELECTRICAL COMPONENTS STAY DRY. FACTOID: 90% OF AIR CONDITIONERS THAT "DONT COOL AS WELL ANYMORE" IS DUE TO DIRTY COILS. THERE IS ALSO A TUBE OR CHANEL THAT DRAINS THE WATER FROM THE EVAP (FRONT) COIL TO THE BACK OF THE UNIT. THAT CONDENSATE WATER IS SUPPOSED TO ACCUMILATE IN A SNALL RESEVOIUR WHERE THE SLINGER RING ON THE OUT SIDE COIL FAN BLADE PICKS IT UP AND HELPS COOL THE HOT CONDENSER COIL. SOME OLDER UNITS MAY NOT HAVE A SLINGER RING AROUND THE OUTSIDE OF THE BLADE. NOW ... MAKE SURE YOUR OUTSIDE FAN BLADE IS CLEAN. AS WELL AS THE INSIDE BLOWER FINS ON THE "SQUIREL CAGE". NOW THAT YOUR UNIT IS CLEAN AND YOU CAN SEE CLEARLY THROUGH BOYH COILS, GO AHEAD AND OIL YOUR MOTOR. CHECK TO SEE IF YOUR FAN MOTOR HAS "OIL CAPS" USUALLY THEY ARE AT THE TOP OF THE 2 ENDS OF THE MOTOR. IF THERE ARE CAPS REMOVE THEM AND USE A STRAIGHT WEIGHT (NON-DETERGENT OIL). SOME WINDOW A/C'S UNDER 12,000 BTU'S ARE SEALED UNITS. IN THAT CASE YOU WILL HAVE TO REMOVE THE UNIT FROM THE WINDOW MOUNTING BRACKET. AND FOLLOW THE SAME PROCEEDURE AS LISTED ABOVE. GOOD LUCK AND STAY DRY.
Posted on Jun 25, 2007
SOURCE:
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
It is dripping water in the house
It should only drip water in the back of the unit, and fall outside of the window or home. You should make sure the unit is leveled correctly with the proper decline to the back. It should have a slight tilt, per the install guide, so that it does not drip into the home.
Aug 28, 2012 | Frigidaire FAH124N2T Air Conditioner
I was wondering where the water goes or if it carrys any water at all. it is a window air conditionor
On a window a/c unit, the water drips outside, so be sure the unit tilts downwards as it goes out. The water is from condensation, sometimes you will get lots, other times almost nothing, both normal, related to actual relative humidity. The water forms due to temperature, it forms exactly like water on the outside of a glass of ice water...
Jul 06, 2011 | Fedders A6P09S2A Air Conditioner
My window unit air conditioner unit is dripping profusely out of the bottom of the unit inside of my apartment. the drip pan is overflowing.
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 04, 2011 | Frigidaire Heating & Cooling
I have 2 of the MSZ-A09NA Mr. Slim model in my 400 sq. ft. cottage. In the summer time my cottage is always damp feeling and the ducts drip condensation. How do I prevent this dripping?
It sounds like you have too much air conditioner vs. conditioned space. This would cause dripping and short run times. Air conditioners are designed not only to cool the house but to pull the moisture out, if it is too big and cools the area too fast the outside of the ducts will begin to collect condensation like the outside of a cold glass of water.
May 04, 2011 | Mitsubishi MS09TW Air Conditioner
No water drips out of the back of the a/c anymore, and it doesn't get as cold.
Either the outside part--- the condensing coil is dirty. If thats not it sounds like its leaked some refrigerant out and would need some added or unit replaced depending on replacement costs
Aug 20, 2010 | Fedders A6D24E7D Wall/Window Air...
Rust colored water is dripping down outside of house, and when unit is on it sounds like constant water dripping.
condensation dripping out of my central air unit is dripping a rust colored water that has stained my house. What is causing this?
Aug 05, 2010 | Frigidaire FAC124 wall/Window Air...
Water dripping inside window opening
I would make sure the 'drain hole' is clear and not stopped up. Sounds like it could be stopped up and you have so much water in the unit it's over-flowing and coming out inside the window.
hope this helps.
p.s. one other thing - you might need to put another hole in the unit (to allow better draining). Typically these units just drip water outside and putting (with a drill) another hole in the bottom of the unit to allow better draining is easily done.
Jun 14, 2010 | Fedders A6X05F2G Wall/Window Air...
Do i have to install my fedders aeq07f2bg on an angle to let the water drain out
It is a good idea to have the rear just slightly lower than the front edge to prevent water (condensate) from dripping inside.
However, most window a/c's use the heat from the unit along with the fan to dispel the water out the back and/or sides of the a/c outside the house.
If you do have the a/c tilted just back a bit, it should prevent any surprises and puddles on the floor, if you leave the a/c running when you're not home, etc.
Hope this helps and best regards!
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
My split type aircon wont work properly, water keep dripping
try cleaning the port for the drain plug, when the air is damp outside it will condence a large amount of water. Aslo make sure unit is level so it will drain properly.
Jul 19, 2009 | Fedders Heating & Cooling
Fedders Y Chassis A6Y18F7A Air Conditioner Logo
304 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Ekse
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
