Question about Logitech Z-2300 Computer Speakers
Left speaker terminal on the sub doesn't work properly
The terminal that i plug the speaker into is not working. It emits the sound very quietly while the other one plays at normal volume. I plugged both speakers into each terminal and both speakers work fine in the one but not in the other. Any way to fix this?
  • 4 more comments
  • shinogo Feb 15, 2009
    I have the same problem, with some compressed air I was able to get both working at full volume for about 2 or 3 minutes, now I cannot repeat this quick-fix. Any help would be much appreciated.
  • Anonymous Apr 01, 2009
    I have exactly same problem ... anyone knows what to do ?
  • Anonymous Apr 27, 2009
    i have the same problem but with the right terminal... :'(
    please help us!
  • Anonymous May 19, 2009
    my problem is exactly the same
    i have exactly the same problem :S does any1 know what to do ?
  • Anonymous May 21, 2009
    How can this problem be fix?
    Scholar:
  • 123 Answers
This is common with the type of powered speakers where the IC package that drives the speakers (the amp) is getting to hot and shuts down. Usually it is damaged and not reversable. There is a lot of reports of this same model loosing one channel or playing quietly. The air most likely cooled the chip down until it heats back up.
Posted on Apr 29, 2009
Problem with edge sub!!
Well it sounds to me like you have a fuse that's rated too low but idk for aure
Jan 14, 2014 | Car Audio & Video
Fader/sub/speaker not working properly
I'm not an expert but often people connect subs to normal speaker wires in back of the radio. You need a dedicated subwoofer line so high frequency sound doesn't go to the subs. Only bass. Sounds like it wasn't wired properly.
Aug 26, 2017 | Pioneer DEH-P6000UB Car CD/ MP3 Player
Speakers aren't emitting sound
The fuses are on the power board at the bottom of the unit. Fuses 901, 902 and 903 are for the left, right and sub speakers. The service manual is here, remember to unplug it from the supply. Page 62 shows PWB C1. The speaker terminals was the answer to your original question.
http://diagramasde.com/diagramas/audio/Sharp%20CD-PC672.pdf
Sep 06, 2017 | Sharp CD-PC672 CD Shelf System
How do i connect the speakers to a pc
What I want you to do is need a little work okay..
In your speaker set there are two satellite speaker which Right and Left. Also it has the sub woofer that contain the three terminals, the red,white and the power terminal. Connect the right speaker to the red terminal, left speaker to the white terminal and the power cord will be connect to the power terminal. In the back of your computer you can see the three sound terminals colors below. Insert the green speaker plug to the green terminal in the sound terminal on the back of your computer.
Oct 21, 2009 | Logitech Z-4 Computer Speakers
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
Surround sound speaker outlets are not working
Hello, I am sorry about your issue. If the speakers work on other terminals then it sounds like a problem with the receiver. It would need to be serviced or traded in. Please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jun 24, 2017 | Onkyo HTR500 Receiver
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Logitech Z-2300 Computer Speakers Logo
504 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
