Question about Jenn-Air 30 in. Pro-Style Electric Single Wall Oven with Multi-Mode Convection
How do you get a Jenn air oven out of the wall???
I have a Jenn Air in the wall oven model W131 that is 13 years old. I need to pull it out to run a tv cable behind it. We have removed the screws on the inside front sides and it still doesn't budge. What's the trick???
Thanks
    President:
  • 1,214 Answers
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Posted on Jan 16, 2009
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My jenn air single oven does not maintain temperatures, when set at 350 it shows 250. It is 15 years old, model #br is W131B
this is what you most likely need. Age, or the clean cycle, can cause them to start to malfunction.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-W131B-%3d%3di1364&PartID=1364
It is inside the oven, and comes out/goes in pretty easily, but you have to be careful when removing the old one, not to loose the wires in the hole, because then you have to pull the unit out from the wall and remove the back in order to plug the new one in.
May 06, 2009 | Jenn-Air JJW8530C Expressions Collection...
Need a manual to operate five year old Jenn Aire wall oven
Jenn Aire model tag are usually at the opening of the door, or may have to pull unit out...be sure to check around the door before pulling out.
Jun 14, 2008 | Maytag MEW5527B Electric Single Oven
Jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air 30 in. Pro-Style Electric Single Wall Oven with Multi-Mode Convection Logo
499 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
