SOURCE: Damaged front Panel on Samsung washer WF206ANS, Where can I get one
If you purchased this appliance NEW, I would strongly recommending getting in touch with the company that you purchased it from. Any damage should be covered under a manufacturer's warranty and should be replaced by them. The reason I mention this to you is because many of the front panel pieces (although plastic) can cost a lot. Especially door facing trim and control panels. You can do the research yourself at repairclinic.com. Type in your model number and use the part index of photos to see if you can identify the part you need. It doesn't makes sense for you to repair something out of pocket if it is a new applaince. AND....if it was possibly damaged during delivery (if this is the case). Post back with your comments and let me know if I can be of further assistance. I hope this helps.
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
