Question about Samsung Digimax S800 Digital Camera
I can't install my card in samsung digimax S800
When i put the card in camera appeared format and i choose yes and then appeared check sd card and i wait but nothing
  • atasieil
    atasieil Dec 25, 2012
    thank you for the solution but i solved the problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
What type and size memory card? The S800 uses MMC and SD cards. It will not work with SDHC cards even though they'll fit into the slot.
Posted on Dec 22, 2012
SOURCE:
Quack
  • 542 Answers
SOURCE: Samsung Digimax 201 and INFINEON 128mB SD Card
Had a similar problem running windows XP, it couldn't read my sandisk SD card on a usb sandisk imagemate reader/writer. The solution on Microsoft's site was worthless, having already applied all XP patches. Fortunately, I tried accessing the SD card under windows 2000 and it worked fine, so I formatted the SD card in windows 2000 and now it works fine in XP.
Posted on Sep 12, 2005
  • 161 Answers
SOURCE: hi,just bought a 4gb sd card for my digimax s600
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Posted on Sep 09, 2009
Testimonial: "hi,thanks for the quick response,i don,t know if it has what you said.it just says on the bottom of the camera..digimax s600 cyber/630."
  • 4 Answers
SOURCE: I purchased a 8gig sd card and tried to put it in
The camera only supports SD memory (limit 2GB), not SDHC (4GB and more). The manual claims up to 1GB guaranteed, though the camera recognizes my 2GB card card.
Posted on Jan 18, 2010
SOURCE: Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
Posted on Sep 07, 2010
  • 102366 Answers
SOURCE: what is the max size sd card used for video in the
SD cards max out at 2GB. Higher capacity cards are actually SDHC cards (the HC stands for High Capacity).
Posted on Feb 20, 2011
On my Samsung Digimax S800, when I put the memory card in, it says to check sd card. What do I do about it?
When the card worked before, check if you did not switch the lock switch down. And check all contacts on the card and in the camera. They should be clean and shiny.
When you recently bought a new card you could have bough a SDHC card and these won't work in your S800.
The S800 only accepts MMC and SD cards, The SDHC and SDXC cards won't work.
A few years ago you still could buy 4 Gbyte SD cards. Now even most 1 Gbyte and 2 Gbyte cards are already SDHC. SDHC was introduced at least 7 or 8 years ago, so all new devices accept SDHC. The SDXC was introduced at least 4 years ago, so in a couple of years, you perhaps only can buy these cards?
Feb 21, 2015 | Samsung Digimax S800 Digital Camera
Memory card after formatting, say check card (samsung camera)
Probably, especially if your card is a 4GB or larger SDHC card, then it's definitely the wrong card. The older Digimax S800 camera can only use standard SD cards (2GB or less). Fortunately, these are very inexpensive these days, and may be found on Amazon if your local store no longer carries them.For others reading this experiencing similar problems, please see this article.
Nov 27, 2011 | PNY 4GB Secure Digital High Capacity...
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
How to format a sd card
Hello and welcome to FixYa!
1- If you want to format it by keeping in digital camera then follow the given procedure:-
  • Put the SD card into your digital camera and then turn the power on. Press the button on your camera to bring up your recently shot photographs.
  • Press the "Menu" or "OK" button on the camera to bring up the photograph options. Choose the option that says either "Setup" or "Options."
  • Scroll over to the "Format" option and hit "OK." Choose the option to set the file format to "FAT16."
2- You can also format it by connecting it to computer through card reader, For it follow the given procedure:-
  • Turn on your computer and put the SD card into the card reader slot on the front of your computer or the external card reader attached to a USB port. Wait to see if your operating system automatically opens a window prompting you for information. Click on the option to "Open a folder to view files" if the window pops up.
  • Click on the "Start" button if your operating system does not automatically prompt you to open a folder. Choose the "My Computer" option to bring up a new window.
  • Right-click on the drive bay for your card reader, and then choose the option that says "Reformat" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
You can also get help from the given video, if you choose second option
If you think this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 09, 2011 | Vivitar ViviCam 3720 Digital Camera
What is the max size sd card used for video in the SAMSUNG DIGIMAX s800
Feb 20, 2011 | Samsung Digimax S800 Digital Camera
I can't get the camera to accept a sd memory card. It keeps saying check sd card, but it's brand new. Why is this?
Are you using a 4GB or higher "SDHC" card with your camera? Note that the S800 can only use "standard" SD cards (those 2GB or less). Fortunately, these are very inexpensive these days, recommend checking on Amazon.
For those that encounter this problem, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jan 05, 2011 | Samsung Digimax S800 Digital Camera
This camera reads "card error" and won't format a
yes. you can try to insert the sd card to a computer using any all-in-1 memory card reader. then if windows detects it, right click the card's drive in windows explorer then select format. choose FAT as file system type. before you put it back to your camera clean the card's contact points, insert the card and if the camera detects the card format it again using the camera's format tool.
Dec 19, 2010 | GE C1033 Digital Camera
HOW TO FORMAT SD CARD
other way to format is Put the SD card in card reader and follow these steps:-
Right-click on the drive bay for your card reader, and then choose the option that says "format" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
good luck
hope it helps if so do rate the solution
Nov 29, 2010 | Kodak EasyShare DX4350 Digital Camera
Samsung Digimax S800 Digital Camera Logo
180 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
