Question about Radio Shack Pro-95 Handheld Scanner
Not picking up any sound
I am not hearing anything on my handheld scanner. I think my grandson has been playing with it.
  • JDBgn May 11, 2010
    Is the battery charged? Have you tried the "search" button. The "SCAN" button? Is it locked out? What do you see on the screen when you turn it on?
  • 27 Answers
When you first turn on the pro 95 and the dual trunking screen is still on insert (gently) a pin or straightened paper clip in the small hole just above and to the right of the external power plug. That will reset the radio. Once it is reset (wait until it finishes resetting) you may need to initialize it. Turn it off then back on, while it is still displaying the dual trunking screen press "0" and then the "1". Do not turn the radio off until the Initializing is finished.
Now re program your radio if you with to use the "SCAN" button. Other wise you should be able to use the "search" button to select the service you wish to listen to.
Hope this helps.
Posted on Aug 01, 2009
Cant pick up stations
Most police stations are using the new motorola trunking units, they are on encrypted custom band channels and you will not be able to hear them. All police helicopters are equipped with them. All i can hear where i live is Fire dispatch, I cant even hear the fire fighters responses .
Nov 11, 2013 | Radio Shack Pro-97 Handheld Scanner
Well my scanner don't pick up any thing any more the Squelch don't turn off to hear anything what can i do to fix it, and all it all worked befor but now it's the Squelch
Hi, my name is John. Check your antenna, try a different location, make sure it is still programed on the frequencies you have in it, some may have changed frequency and you did not know it.....hope this was helpful....Rate this solution on the four thumbs-up.....John
Sep 10, 2010 | Uniden BC72XLT Handheld Scanner
I can not get any sound out of my radio shack pro 97 scanner I turn the volume all the way up and hear a light uzzin sound I have it on the weather channel and no sounds my scanner saids all channels...
Nothing's wrong. All of your frequencies have been deleted (pre-programmed PLUS anything you entered yourself).
You'll need to re-enter all of the frequencies to get it working again.
Oct 26, 2009 | Radio Shack Pro-97 Handheld Scanner
How to clone 97 pro radio shack scanner
my husband had 1 of those.they do not work at all.
Sep 23, 2009 | Radio Shack Pro-97 Handheld Scanner
My radio shack digital scanner will not pick up in my house.
try getting your hands on an outside mounted antenna.It will work very good!
Sep 16, 2009 | Radio Shack Pro-95 Handheld Scanner
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
Scanners
Other than size of the scanners there is no difference. I used to think that a home Base station scanner would work better. This is not true. Every scanner I purchase now is a portable. I use them at home and even hook them up to an antenna on the roof. They work great and you always have a choice to take them on the road with you.
Your problem specifically sounds like it is probably a programming error. Take a look at you frequencies on Radioreference.com to make sure you have the most current. then look up in you manual the programming section in your manual and plug in the frequencies and it should work fine.
elijam1
http://www.scannermaster.com/?Click=37131
Nov 18, 2008 | Uniden BC72XLT Handheld Scanner
How to scan frequencies quietly
Yes...adjust the squelch control. This is usually a knob adjacent to your volume control. This should eliminate the static noise and you will only hear audio when someone is transmitting.
Nov 17, 2008 | Uniden BC72XLT Handheld Scanner
Symbol handheld scanner problems
scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Aug 11, 2008 | Symbol LS2208 Handheld
Motorola HS810
sounds like you need a new headset..
Mar 17, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Radio Shack Pro-95 Handheld Scanner Logo
146 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
