Question about Dishwashers
The bottom does not seem to go around - Dishwashers
What model? does the unit drain?
Posted on Jan 16, 2009
Polaris 380 wont run when vertical
The drive belts are loose. Replace the drive belts are at least take the cover off inspect and tighten. The adjustments are the axle blocks. Tighten to where there is about an 1/8" tension while lightly pushing on the belt.
Aug 27, 2009 | Polaris 380 In Ground Pool Cleaner
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
Overheating
When you mention the radiator having a hot upper in pipe and a cool bottom out pipe tells me that the coolant is not moving around the engine. This could be down to a water pump not working, blocked radiator, thermostat not opening. The bottom hose should be cooler than the top hose but once the engine is up to working temp which is around 85/90 degrees c for an audi the bottom still should be farly hot to touch. Hope this helps
Jun 01, 2009 | 1996 Audi A4
Speedometer is jumping around
The speedometer cable needs lubricating. It can be removed from the bottom where it connects to transmission, coated with graphite and reinstalled.
Apr 28, 2009 | 1991 Chevrolet Lumina
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
1994 Ford Econovan: drain coolant
yes remove the bottom radiator hose from the radiator. problem solved
May 25, 2008 | 1994 Ford Econoline
The belt for my maytag dryer seems to long and i have it on the pulleys and the drum. am i suppose to loop again around the idle pulley
route it from the motor straight up around the drum, from the bottom of the drum back to the motor, and then out around the tensioner
Apr 16, 2008 | Dryers
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
