Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Gas fireplace question
I flip the switch and it turns on. Is there something else I should turn on to help blow the heat out? If so, where is that apparatus?
    President:
  • 1,214 Answers
Simulated gas log fireplaces usually don't have a blower of any type. They depend on the radiant and conducted heat much like there was a real wood fire in the firebox. Look in the manual to determine if a blower was included, but I doubt it because of risk that CO would be propelled into the living space.
Posted on Jan 15, 2009
How do I clean the inside of the glass of the fireplace?
Crumple up newspaper, use it like a rag, scrubbing the glass. Not abrasive enough to scratch the glass but enough to clean soot deposits.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to clean your Fireplace Glass
Gas Fireplace Repair Dirty Glass My Gas Fireplace Repair
How To Clean Your Wood Stove Fireplace Glass
Cleaning glass on woodburner
Mar 02, 2016 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
How can i fix my gas fire place
You can't unless you a government registered gas fitter. Incorrectly installed or serviced appliances gas people and blow up homes. Get someone in to service it.
Nov 15, 2015 | Napoleon 36" Zero Clearance Top/Rear Vent...
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
My 2 year extended warranty just ended 17 says ago and my electric fireplace (QCM707-32) breaks. The heater portion seems to be the defective part. The blower seems to be out. I can turn on the fireplace...
Simple I should think the thermostats have gone. These are silver round objects with one wire in and one wire out. They have a bimetallic disc inside which flips when a certain predetermined temperature is reached. Sounds like yours is flipping out fairly quickly. Can you hear the fire click just after the element starts turning orange? These thermostats are fairly universal and have a number on them which determines the value. Before investigation definitely unplug the fire as this ill definitely kill you!! You can check the thermostat by disconnecting the wires, and checking the resistance from each terminal when it is cold, it should be an open circuit.....no reading....a simple way to see if it is tripping out very quickly, heat it gently with a hair dryer...if it clicks really quickly......definitely the stat. Also, if there is a trip switch, this would indicate a different fault such as a faulty or burnt wire causing a short circuit. Hopefully this is not the case, especially as it seems you are not blowing a fuse or tripping your fuse box. Good luck. Stats on eBay, same as the type that are used in tumble dryers.
Nov 24, 2013 | Heating & Cooling
We purchased a home with an electric start/gas fireplace...no owners manual...we turned on the gas with the key, flipped the switches on the wall and the fireplace unit...we see the ignitor clicking and a...
Not for sure what you have, but if you just purchased the house, there might be air in the gas lines. If it sat vacant and the gas was off, or if they has swapped meters/worked on gas lines? Try cycling the fireplace several times. Or look around for a small door opening or if it's mounted to the exterior wall, look outside for the supply line in. If you do find a valve in the closed position, be aware of the fact that it may be off due to a reason, and you may want a plumber/fire place tech to service it.
Oct 19, 2017 | Leisure HOMEPRIDE Electric Fireplace...
I have a gas fireplace with a typical sinle pole light switch to turn the gas fireplace on and off. I'd like to replace the switch with a timer type device, but it's low voltage. One red wire and one...
Any timer will work as long as you don't exceed the voltage. The switch you have now is simply breaking one wire, when you flip the switch it lets the wire complete its circuit, a timer does the same thing and the voltage really has nothing to do with it other than a 220 switch would have to break 2 wires .
Hope this helps and please don
Nov 22, 2010 | Heating & Cooling
My fireplace pilot light can be lit but when I flip the switch to turn the fireplace on and the pilot light blows out
First, and least expensive thing to do is replace the thermocouple. Probably weak.
Hope this helps.
Nov 18, 2009 | Ovens
Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Dec 01, 2008 | Heating & Cooling
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
185 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
