Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Front Screen rotector is Spiderwebbed
Where can I get a Screen protector at? I have be everywhere!
  • 298 Answers
You can find RCA original replacement protective screen (super shield) and screen assembly for a model # D52W20 from a major parts distributor at the following links:
RCA D52W20 Replacement Part Protective Screen / Super Shield
RCA D52W20 Replacement Part Screen Assembly
Posted on Jan 16, 2009
  • RCA Master
  • 8,617 Answers
You can get them here at the following link, just hit the contact button and send them a email with your model number and what youre needing.
http://servicemanuals.vstore.ca/
Removing a screen protector on a Hitachi 57F10A
You might try Hitachi for the service manual with full breakdown.
Basically the entire front screen unit comes off from the front in one piece, then inner two screens come out--carefully! and then frame needs to be partly pulled apart to get out screen from rear as it is in a slot all around the frame.
Apr 10, 2012 | Hitachi Televison & Video
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
I need to remove screen protector on my hitachi 65" big screen tv
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).
Once this strip is removed, you should be able to see a gap (~2mm) between the top of the protector and the frame. Pull the middle of the protector toward you (you may need to hook it with something like a chrochet hook to get it out to where you can get a finger on it). Pull out one side of the protector, then work it loose fromt he bottom. (If it is stubborn, you may have to loosen the bottom frame. Take of the speaker grill, then unscrew the screw on the bottom of the surround for the control panel and pop the surround out. Then there are 3 screws that hold the cabinet frame {might me different for the 58B} and beneath that, 3 screws that hold the bottom of the inside frame. Once those are removed, you should be able to flex the inside frame enough to loosen the protector.)
Installation is the reverse. There are two grooves (at least on my set), and the protector goes in the rear groove(!) (same as the screen itself - first time I tried to put it in the unused groove closer to the front of the screen, and that iddn't work). The black plastic retainer strip goes in the front groove.
Jul 18, 2009 | Hitachi 43F300 43" Rear Projection...
SCRATCH ON SCREEN
front screen is a protector but also helps with the image quality. new screen runs about 190 dollars
Jun 02, 2009 | Akai PT61DL34 Television
Toshiba 50HDX82 Screen Protector
First remove the speaker grill. Then removed the control package via two screws. This should expose the screws that hold the front mask on. You can then slide the mask up and inch or so then pull it forward. Hope this helps.
Jul 16, 2008 | Toshiba 50HDX82 50" Rear Projection...
Need to know how to replace screen protector shield
you have to take off the speaker grill on the front... it just pops off, it's a little unnerving yanking on it but it will come off with a little force. Then there are similar screws on the front of it.
Jun 17, 2008 | Toshiba 57H84 57" Rear Projection...
Removing a screen protector from a Hitachi 50UX58B Projection color TV
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).ea84b4b.jpg
Mar 22, 2008 | Hitachi 50UX58B 50" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Toshiba TP55h60 55in television
contact rca or hitachi for a sub screen.
Sep 10, 2007 | Toshiba TP55H60 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
159 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
