Question about Yamaha RX-V661 Receiver
Static noise from Front Left Speaker
I noiced some extra noise coming from the front left speaker only one day so I decided to use the auto set up with the included microphone. All went went until it got the front left speaker, a loud pop of sound came out of the speakers and the receiver shut off. I turned it back on, same thing. Checked all wiring, good there. If there is a short, would it be with the speaker or the receiver?
  • 948 Answers
It would probably be with the speaker. That is easily checked by simply unhooking the speaker and running the test again.
Posted on Jan 15, 2009
95 Jeep Wrangler wiring harnesses broke down by color to show where each wire goes to
Car Radio Constant 12V+ Wire: Red/White Car Radio Switched 12V+ Wire: Purple/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Blue/Red Car Radio Dimmer Wire: Red/Black Car Radio Antenna Trigger Wire: N/A Car Radio Amp Trigger Wire: N/A Front Speakers Size: 4? x 6? Speakers Front Speakers Location: Dash Left Front Speaker Wire (+): Gray Left Front Speaker Wire (-): Yellow Right Front Speaker Wire (+): White/Red Right Front Speaker Wire (-): Brown/Red Rear Speakers Size: 4? Speakers Rear Speakers Location: Rear Roof Left Rear Speaker Wire (+): Gray/White Left Rear Speaker Wire (-): Brown/White Right Rear Speaker Wire (+): White/Black Right Rear Speaker Wire (-): Brown
Oct 04, 2016 | Crown Jeep Wrangler yj 95 94 93 92 91 90...
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
Left Speaker Jack only produces static
That is probably happened to an aging speaker.
Consider buying a new one or try to rewire the coil inside the speaker magnet.
Jun 01, 2010 | Bose Companion III Computer Speakers
When opening door with car off static comes from radio speakers, and left front speaker doesn't work
Check the speaker wiring in that door and the rubber tunnel going between the door and post. likely the wire is chaffed and grounding Noise will show up in all speakers when that happens.
Sep 19, 2009 | 2001 Chevrolet Impala
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Yamaha RX-V661 Receiver Logo
661 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
