Small single post connetors and USB connector
System Board: A Open MX46-533V. Client asked me to repair computer's Front Panel USB connectors and sound. Running Win XP HE with a P-4 processor running at 2.79 Mhz. System has 2 GB PC-2700 RAM.
There are numerous little single post connecting wires hanging loose inside the cabinet! They are labeled but, while the System Board provides a number little pins for them to go on, I have no clue as to what goes where. The location of a schematic would be of great benefit. Thanks,
Cyber Mech
  • cyberserver Jan 20, 2009
    Outstanding! Just what I needed!! Thanks.
    Sergeant:
  • 238 Answers
You just need the manual, not a schematic. Try the aopen site: http://download.aopen.com.tw/Default.aspx
If you have trouble, get back to me and I'll download it and send you a copy.
Posted on Jan 17, 2009
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
Emachine W3653 motherboard manual
Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Above shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtml
Click on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I can't find the usb comnector for my wireless mouse and keyboard do my new HP 310 touchsmart desktop...where is that thing? Thanks
this is the your work let the follow of instruction ..
Front USB connectors removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: Click here to view the precautions . CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data.
  2. Power down the server.
  3. Remove the bezel.
  4. Remove the access panel. Click here for instructions on how to remove the access panel .
  5. Disconnect the front USB cable from the system board and unroute it.
  6. Remove the two Torx T-15 screws that secure the Front USB connectors to the chassis.
  7. Remove the Front USB connectors from the chassis and thread the cable out of the opening in the chassis.
Front USB connectors replacement
  1. Thread the front USB cable through the opening in the chassis and insert the Front USB connectors to the chassis, ensuring that the key aligns with the slot.
  2. Replace the two Torx T-15 screws that secure the Front USB connectors to the chassis.
  3. Route the front USB cable to the system board and reconnect it to the system board.
  4. Replace the access panel. Click here for instructions on how to replace the access panel .
  5. Replace the bezel.
Apr 17, 2011 | HP Televison & Video
I want to connect My front USB to the Gigabyte MB ga-945p-s3 i dont know how to do it right if there is a video to show me how to do it, that would be great your help is needed thanks
There are two connectors on the motherboard marked F_USB1 and F_USB2 for the front panel USB ports. This is the page from the manual (you can download a copy here) for your board:
The pinout of each USB connector is the same, so it does not matter which one you use. Each connector supports two USB ports. The pin assignments are a standard, and the cable from the front panel USB connectors in your computer case may already have a plug on the end which will fit. Note the missing pin (pin 9); the plug is keyed so it will only fit one way so you can't put it on backwards.
If the front USB cable in your computer case doesn't have a 10-pin plug on the end, it will have a separate single-pin connector on each wire, and they will be marked with their function. Make sure you match each wire to the correct pin on the board, following the chart shown above.
You should have your front USB working very quickly. Thanks for using Fixya!
Dec 03, 2010 | Computers & Internet
Where would I look for the usb port
Most Compaqs (in general all brands) have USB ports on both the front and rear of the case. The rear connectors are found where all the other I/O connections are located. They are flat rectangular sockets. When you want to plug in a USB device, you can plug into any open USB port. The plug will also only fit one way, so if it will not go into the connector just flip it over.
Front panel USB connectors are often hidden behind a door. Look for a swing-open or slide-down panel. On some cases the connectors may be on the top or sides.
When connecting devices such as a printer or external hard drive, you should use the rear-panel USB ports. These go directly into the system board and have the best performance. Front-panel USB connectors plug into the main board with cables. For most devices (including your SanDisk) it doesn't matter which you use, but the rear-panel ones are best for high-speed devices or moving lots of data.
You can usually find the user's guide online at the computer manufacturer's website, and that will show you where all the connector are on your system.
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Feb 21, 2009 | Compaq Computers & Internet
Location firewire input port
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Nov 01, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
Front usb connections
I finally found a solution, on a dead page in google cache only:
http://www.pcclub.com/forum/messageview.cfm?catid=27%26threadid=16567
The solution was posted by JontyBonkers.
The pins go like this:
1 2 3 4 5
_ 6 7 _ 8
1 = ground
2 = ground
3 = D1-
4 = ground
5 = D1+
6 = D2-
7 = D2+
8 = +5V
It seems that the case for those Packard-Bells had a small circuit board that divided the 5V line to both sockets.
D- are usually white, D+ - green, 5V - red, ground - black
Jun 11, 2008 | Packard Bell Computers & Internet
Power connetor from front panel
Look on the board you gotta have good eye sight it will tell you LED plug into that.
Sep 30, 2007 | Micro Electronics PowerSpec 8250 PC...
Computers & Internet Logo
421 people viewed this question
David Payne
David Payne
