Question about HP Pavilion dv9000z Notebook
Disc drive wont open on its own, and doesn't click back in place.
I dropped my laptop, and now the disc drive doesn't shut properly and the only way to open it is to put a pin in the little eject hole on the side.
please help!
  • 98 Answers
There is no solution that could help you to fix this problem on your own.
There are two possibilities:
  • if your disk drive cannot read disks - hardware failure - most probably replacement needed or
  • if your disk drive can read disks - the open button is stuck - take it to the repair store.
Posted on Jan 15, 2009
    President:
  • 2,559 Answers
It needs replacing,not really much you can do to fix them.
Lenovo Z570 Disc tray is stuck -outside of laptop
Open the try slightly, shut down the machine, tilt the machine to the side of the DVD/CD drive a gently shake to loosen the tray or whatever is causing the problem, Is the disk off the spindle? Is the dvd/cd broken? Can you insert something to clear whatever is obstructing it? Have you tried to eject using the software, Go to computer, right click DVD/CD rom drive, click on eject? Has there been any damage to that area, bent..etc? You may have to force it open or remove the drive and try to open it.
Nov 19, 2012 | Lenovo Computers & Internet
Why wont my cd drive work
see this and fix it. God bless you
Turn on your computer and open the CD drive by pressing a small button on the front of the drive. Use a can of compressed air to clean the lens by spraying a few squirts of the air into the drive. This will fix disc skipping if there was dust on the lens.
  • 2 Place a CD drive cleaner into the disc drive. This is a disc that is specifically designed to clean CD drives. Allow it to run for a few minutes, and then extract the disc from the optical drive.
  • 3 Click the "Start" button and then click on the "All Programs" option. Click on the "Windows Update" icon and then click the "Check for Updates" button on the left side of the screen. Click the "Install Updates" button at the bottom of the screen to update the drivers for your CD drive. Restart your computer for the driver changes to take effect.
  • 4 Unplug the power cable from your computer and use a screwdriver to open the tower door. Locate the CD drive cables inside the computer. Make sure that the CD drive cables have not loosened. If the cables are loose, then the drive will not operate properly.
  • Sep 27, 2012 | Acer Computers & Internet
    Dvd reading error
    Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
    Sep 22, 2012 | HP Pavilion dv6775us Notebook
    Why isnt my laptop reading discs?
    Try removing the drive and insert it again so it connects properly. If this doesn't fix your problem then most likely the drive is faulty and needs replacing.
    Apr 15, 2012 | E-Machines eMachines M5305DP Notebook
    Xbox360 disc tray motor won't stop spinning
    Hi Matt,
    Here is the process for troubleshooting this specific issue:
    • First remove your disc from the tray. I assume you have already done this.
    • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
    • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
    • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
    Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
    Hope that helps!
    Feb 10, 2012 | Microsoft Xbox 360 Console
    My daughter dropped her laptop now it wont turn on and keeps saying theres a hard drive prpoblem
    Well, either the hard drive inside has come loose from it connector, in which case opening the access door on the back and re-seating the connector will solve your problem, OR, the impact from the dropping has resulting in hard drive crash in which case you need a new hard drive.
    Jan 20, 2012 | Toshiba Computers & Internet
    Describe how you insert a dvd into a laptop
    Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
    Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
    Console turns on but wont read the disc. everything else works ok, message comes up saying reading then changes to open the drawer.
    I have this problem after searching this fault on the net I found it to be the Lens sticking on the rails if the Xbox isn't shut down properly the lens assembly stays at the far end of it's track out of reach of DVDs & Games. I don't recommend this if your not handy with electronic devices or it's under warrenty but search the net for the fix & pull it apart, eventualy you'll get to the drive open it & thers the problem. just push it back into place put it all back togeather try it & shut it down properly each time & it should work mine still does
    Feb 06, 2011 | Microsoft Xbox 360 Console
    Psp wont read the disc unless you hold the door shut w/o ...
    If you dropped it, then the reader may be a little messed up. If the case around the disc is popped open a little bit, closing it all the way might stop the disc from spinning, resulting in not reading the disc. The only thing I recommend is to contact Customer Support on the Playstation website. They might be able to help you fix the problem or have you send it in. www.playstation.com
    Apr 29, 2009 | Sony PlayStation Portable (PSP) Console
    Dropped console, now get 'unreadable disc' erro
    wont open, wont close, makes clicking/grinding noises etc.
    http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
    Apr 08, 2008 | Microsoft Xbox 360 Console
    HP Pavilion dv9000z Notebook Logo
    54 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
