Question about RIM BlackBerry Curve 8310 Smartphone
Memo on blackberry 8310
I originally had a 8700c blackberry and I created memos on it, when I used my desktop manager when I rec'd my new 8310, the memos came over. And I can edit them, but I'd like to know how to create new ones.
  • 561 Answers
On 8310 the MemoPad may be located in the Applications folder on your Desktop. If you can not locate it, you should download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Posted on Jan 15, 2010
Tip
How do i send a voice memo with my blackberry 8830?
The BlackBerry 8830 smart phone, and other BlackBerry phones, come with an application to record voice memos called "Voice Notes Recorder." From this application you can create, store and send voice memos directly from your phone. You do not need to upload the memo on the computer or send it through email (unless the recipient cannot receive multimedia messages).<span><br /></span><br /> <span> <span>Instructions</span> <ol> <li><span>Open "Voice Notes Recorder" on your phone.</span></li> <li><span></span><span>Press the trackball to record the voice memo. Press it again to stop recording.</span></li> <li><span></span><span>Scroll to and select the mail icon while the memo is stopped.</span></li> <li><span></span><span>Select "Send as MMS."</span></li> <li><span></span><span>Choose the contact from the list, or choose "Use Once" and type the phone number of the recipient.</span></li> <li><span></span><span>Add a note to the message if you wish.</span></li> <li><span></span><span>Press the "Menu" button and select "Send" to send the voice memo and message.</span></li></ol></span>
on Mar 12, 2011 | Cell Phones
Downloaded update for blackberry 8310
open back the desktop manager and then the apploader and then load the memo pad and tasks
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve 8320 How to acces notepad items on my PC
Memos are stowed on the phone itself, and are abled to be viewed when the phone is synched with the BlackBerry Software.
Jun 28, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Verizon Blackberry Curve 8330 Calendar
you can transfer your information from your palm to your blackberry with a connection cable and your pc or laptop
May 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Problem when I sync blackberry curve with desktop via USB
Open your desktop manager, and select the functions you want to Sync, I would start with out the memopad and see if it syncs, if not then dont sync tasks and see if that fixes the issue...
Hope this helps, if so please rate accordingly
Thanks, David
Mar 14, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry Curve & Outlook 2007
I've had a few clients with this issue. I have used these steps from RIM. Try it and see if it helps.
Here’s what you need to do:
1. Uninstall Desktop Manager
2. Remove any references on your registry and on your C drive program files and users to:
a. Blackberry
b. Pumatech
c. Research in Motion
d. RIM
e. Desktop Manager
3. Disable the UAC (User Accounts) on Control Panel-Users
4. Get a command prompt and type regsvr32 atl.dll (enter)
5. Reboot
6. Make sure that when you re-install you have absolutely no SpyBot, Virus, Spam guard or the like running.
7. Reinstall Desktop Manager (version 4.2 SP2)
8. If you get an “Error 1904….Lotus Notes…” Ignore it
9. After you do all this, it should work
Jan 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
Dictate memo
Absolutely. You can create a voice memo for about 15 minutes. Want more time, just leave the recorder going and it will create a new spot and just keep going.
Dec 26, 2008 | AT&T Blackberry Curve 8300 Smartphone
To get rid of the unknown error, you will need to uninstall the Blackberry Desktop software. When you do this, make sure that you have the uninstaller delete the user settings, too. Then reinstall Desktop Manager 4.3. See if that helps with the syncing, too. This solution solved the error problem for me, so I hope it will work for you.
If this does not solve the syncing problem, then post back here again and we'll look for another solution. Sometimes a .pst file repair will help.
Jun 04, 2008 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Pearl missing apps?
I accidentally deleted memo and task. I went to the blackberry site and downloaded the updated desktop manager software. After it was installed, I went to "backup" tab and it gave me the option of selecting those programs and I got them back:). Hope this works for you!
Dec 29, 2007 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8310 Smartphone Logo
249 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
