Each time I try to print a picture this message is displayed: The photo tray is blocked. Please adjust the tray and try again. I have reset the printer and no change. I have downloaded the hp print dr and it says everything checks o.k. I have taken all except one piece of photo paper out of the tray and still I get the error msg. Please help!
SOURCE: Fax
Often, this type of problem is caused by the paper sensor which is nothing but a small switch activated with the presence of the paper(s) pressing on it, It would look like a small tab/lever that would move (to activate the switch) by the paper pushing against it. You would have to inspect this lever/switch and determine if it would move freely. It is very rare for the actual switch to go bad, often it would be just the tab/lever not depressing deep enough to engage said switch.
Hope that this beof initial idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
SOURCE: sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
SOURCE: I am having trouble with the printer. The DR is
Definitely you have a problem with the printer.
That will not prevent you from sending faxes out, but did you try to make a copy?
If the machine sat idle for some time, the ink in the jets would have dried, but this will not generate any error messages.
There are cleaning kits available, and they usually work.
SOURCE: I HAVE A C4280 ALL
remove all cartridges remove adaper and usb cable from the back side of printer turn off printer for 5 min put cartridges into the printer offline , then plug power adapter and usb cable turn on the printer load white paper in tray print allignment page put on scanner press ok , hope this will wrk for u,
reguard
Photo tray problem
' Lift the output
tray up and verify that the photo tray ' is pushed in until it stops, then lower
output all the ' way down. Press OK
button on the printer to 'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper
tray and photo tray
3. Remove output
duplexer (on back of printer)
4. Open input sheet
feeder (on top of printer)
5. Open cartridge
access door. (Basically lift up control panel and scanner section of the
printer)
6. Turn on printer
(Power button on now raised control panel)
7. Printer may
display message "Performing printer alignment - Do not interrupt"
8. Wait for a few
minutes until printer stops making all setup noises.
9. Close cartridge
access door, close input sheet feeder, replace output duplexer, insert paper
trays
10. Do a test print. All should be fine.
