Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Trouble with waterheater
We got a new waterheater for our mobilehome the one we had was a 40gal we could not find a 40gal so we got a 30gal the water does not get very hot and does not stay hot could it be the wrong orfice because they told us this waterheater couldbe used for propane or natural gas we have natural gasa
    President:
  • 1,214 Answers
DO NOT USE THIS HEATER UNTIL IT HAS BEEN CHECKED OUT BY A PROFESSIONAL!
Most all gas appliances can use propane or natural gas, but they ship from the factory with orifices for one or the other.
Propane is rated at 11 iwg, natural gas at 7 iwg (where iwg=inches water gauge. 27 iwg=1 psig) (it takes a different regulator spring to handle this small difference in pressure.
A propane orifice will be smaller than a natural gas orifice.
The store that you bought the water heater should know what they sold you, and know if they have a kit to convert the regulator and orifices.
Posted on Jan 16, 2009
Tip
Find your only getting Luke warm water @ your faucets??
This is a common fault with new to used installed waterheater.
It is call a diptube ,made of pvc in part description. It is located on cold inlet,top of waterheater.
Malfunction of dip tube is usually a fracture caused by age mostly,or faulty install when new and tube was exposed to high heat from welding .
This tube allows the cold water supply to flow into W/heater and exit at bottom where it is heated while pushing already heated water to hot side and to your faucet. If this tube is defective ei...cracked the cold will [leak] mix with the hot before reaching bottom to be heat..thus lukewarm water syndrome. Solution $8 part H/depot>remove coldside copper fittings and pull white pvc out,about 4feet long,less rotted area, install new 3/4 inch pvc dip tube with flange up.
Thanks jj505 The HomeRepairman
jthomefix@gmail.com
on Apr 13, 2009 | General Electric GE SmartWater Household...
New 40gal Kenmore water heater flashes 10 times
Copy following link to identify gas control valve and download error code and general service manual:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
h
Oct 22, 2013 | Water Heaters
On demand hot water heater leaking
is this an area w/a threaded fitting?if so ,you turn off waterheater,drain,disconnect existing fitting,clean and rewrap with new teflon tape ,and retighten down.i only say to drain,because i am not sure if it is hanging and would not want to fall on you.teflon tape and rewrenching down should fix,unless soldered.then call your plumber.also if under warr.from installer ,less than 1 yr.,call them and tell them to fix it for free.i have over 13yrs in sheetmetal install,both in hvy.industrial down to many other types of home install of furnaces,a/c units,retrofits in /new and existing homes,waterheaters,garbage disp,refrig.water lines,gas etc
May 21, 2012 | Bosch Water Heaters
Elec water heater 40gal water way to hot and blowing braker on the water tank Red reset button what wrong please help
One of the thermostats is bad or there is corrosion behind it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 14, 2011 | Water Heaters
My reliance electric hot water heater keeps shutting down. when I push the reset button it goes on and works for anywhere from 1 day to 5 weeks. Where do I look for a solution.
According to Reliance's trouble shooting guide, you may have faulty upper thermostat that is overheating, which is causing the high temp limit switch to open and shut it down. Pushing the reset switch is only a temporary solution until you find out what is causing it to shut down. Is it still under warranty? Call Reliance and find out. 1-800-365-4054
May 17, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Jockey pump for hot waterheater. Suddenly no hot
some times you can, if their is a check valve on the system. These check valves some times fail and cause this problem.
Mar 20, 2010 | Grundfos Plumbing
My mom has a RHEEM 40gal electric hot water heater...model 87H 40D 1PH, Serial # r0288003951. It is the table top version. She said that the hot water is no longer working and before I request a service...
first check that the thermostat is working im afraid if its not a fualt there the chances are its the element in theboiler that means a new boiler in most cases
Nov 13, 2009 | Water Rheem MR40245 Marathon Electric ...
Heating & Cooling Logo
126 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
