Question about Lexmark Z1420 Printer
Does not print
Loaded drivers for printer off line printed one page one day next day would not print says printer is offline
    Novelist:
  • 180 Answers
Check this..right click your printer and see if you have a choice to Use printer online. Select that and it should say Ready under your icon. If not, we'll try something else.
Posted on Jan 16, 2009
Printer wont print says its offline
Dear
Click on START-PRINTER AND FAXES-right click on the PRINTER ICON-click on USE PRINTER ON LINE.
If this is not working connect(replace the cable with a known working cable) the usb cable at the back panel usb port(or change the usb port) of the PC.
If this is not working un install the printer driver and reinstall the same.
If this is not working the printer hardware failure may be there you may need assistance of trained personnel.
Thanks.
Feb 25, 2015 | Office Equipment & Supplies
I have just bought and loaded a new HP cartridge black ink 21 for 1400 series. Test page prints ok but printer is now offline. I have turned on/off, reloaded cartridge, checked printer drivers are up to...
Kindly check if you have pending print outs on your computer, if you do just delete those.
Else check if you have set the printer on default printer may be your printer is not the default one.
Thanks.
Mar 17, 2011 | Office Equipment & Supplies
I try to print & my PC print que says "printing" but it also say the printer is offline. How do I get it back on line?
If you printer is USB you should shut down your computer. Next turn off your printer. Unplug the USB cord of the printer. Boot the computer. Turn on the printer power. Plug in the printer USB cord. The computer should find the printer and load the driver. Go to control panel and look for printers. Find your printer. Right click your mouse on your printer and set it as default printer. Now it should work when you try to print to it.
Mar 05, 2011 | Office Equipment & Supplies
Offline message
if the computer says printer off line then they are not comunicating try to reload driver
Jul 28, 2010 | HP Office Equipment & Supplies
We print to the printer through a windows driver but have to push go each time to print the page.
not required to press the go button . if the printer is in of line at that time you give print means you have to press the go button... to know the printer status.... if the ready light is on .. printer is online ... ready light off the printer is offline....... use correct printer driver for avoid junk print.....
Oct 15, 2009 | Kyocera Mita FS-1920 Laser Printer
How to switch from "offline" status to "online" status
I was also facing the same Problem, I solved it by following these steps
First I noted down the IP address from the Printer, Menu > Network > Wlan > Tcp/IP
then on my pc
1.Point to Printers and faxes 2.add new printer 3.a welcome window appeared click next --select local printer attached to this computer do not check automatically detect............. then click "Next" 4. Point to Create a New port then select HP Tcp/IP Port 5. a Welcome page appears again click Next 6. Now is the time to Write the IP address you noted earlier from the Printer also check Always print to this.......... 7. now by clicking ok or Next it will take some time to load another window 8. Now at the bottom left of this window you will find two options i selected the "custom" option, another window appeared click ok and wait for few seconds, when that disappear click Next Click finish and wait.......... 9. Here You go another window appeared Point to the Manufacturer Brother and then select the model MFC6490 10.Click Next and Point to KEEP THE EXISTING.......... or whatever option you like.. Now its easy follow the on screen steps untill you are asked to PRINT A TEST PAGE
NOW YOU ARE CONNECTED AND ONLINE AND ENJOY....
BUT HAY THE OTHER DAY I FOUND THE SAME PROBLEM "YOUR PRINTER IS OFFLINE" DON'T WORRY, i SOLVED THAT TOO 1--GET TO PRINTERS AND FAXES 2--SELECT THE PRINTER WHICH IS ALREADY INSTALLED AND SAYING " OFFLINE " 3--RIGHT CLICK AND POINT TO "USE PRINT ONLINE" THERE YOU ON FLY AGAIN!!!!!!!!!!!
THANKS MUHAMMAD IMTIAZ KHAN
Apr 02, 2009 | Brother MFC 6490CW InkJet Printer
Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp printer 5420 photosmart
sadone:
I assume all hardware connections are fine, and any lose cable connections are already checked then......
1)Send a test page to the printer Open up the print jobs, and try deleting all jobs (click on the printer from printer and faxes under control panel, delete all print jobs, Still in this window click printer and uncheck the print offline, does this help?) if not then
2)Try uninstalling and reinstalling the printer driver and then try printing a test page.
3)Try uninstalling and reinstalling the printer software and driver and then try printing a test page.
If nothing works then:
-Uninstall all printer software, driver unplug and reseat an original hp cartridge and go this link install software and driver and follow instructions on how to install the drivers, at the end click the check button to see if driver is fine. Now you should be able to print.
Dec 24, 2007 | Office Equipment & Supplies
Prints lines of garbage
This sounds like a driver issue, the wrong driver may be in use or may be corrupted. Go into Control Panel > Printers and delete the printer, then reinstall it using the drivers that came with the printer. Let me know how it works out!
Jun 06, 2007 | HP LaserJet 2550L Printer
Canon i860 "printer offline" but light is blinking
Move mouse pointer on to your printer icon in the Printer folder. Does a right click and click on the sixth line of the menu (“Use printer on line”). Then it will change as “Use printer offline”. Make sure the printer is set as default printer.
Oct 17, 2006 | Canon i860 InkJet Photo Printer
Lexmark Z1420 Printer Logo
80 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
