Question about Vehicle Parts & Accessories
Alarm &immobiliser my alarm fob has broken so i disconnected the earth to shut off the noise. the car wont start on the key but runs normally when bumpstarted. i phoned my local vauxhall dealer about a new fob but the guy said the starting problem was not related to the alarm. I found this somewhat confusing as it started perfectly well before. Any advise would be appreciated. Thankyou.
  • 16 more comments
  • pedropony2 Jan 16, 2009
    Because of the position of the alarm siren i dont think it can be but not sure.
    I havent owned it from new. The siren is under the bonnet above the radiator.
    Bump starting is starting by rolling the car then releasing the clutch whilst in gear.
    That was my thinking Te untill the guy at vauxhall said it wasnt.
    Never had a problem starting untill this alarm went wrong.
    Lol bunny can remember doing that back in the day when starter motors were accesible.
    Forgot to mention that i have taken starter motor off and it did run off direct power although somewhat slowly.
    Will try that in the morning as its dark here already.
    Thanks for all your input, will post result asap.
    Pete.
    No probs ed.
    Just thought i would try and shut him up as he is getting on my nerves.
  • pedropony2 Jan 18, 2009
    Have found where the alarm is spliced into the harness behind the glove box. Have reconnected these and still wont start on key.
    Have a nasty feeling this could be a problem with electronic ignition as the wife now tells me she smelled something burning the day before this all happened. Will there be a fuse for the ignition that i can check?
  • pedropony2 Jan 19, 2009
    Armed with all this info i phoned a local auto tech who has disconnected the alarm from the ignition system and all is well.
    Many thanks for all your help which as always was spot on.
  • Toyota Ed May 11, 2010
    Thanks.
    @ Pedro....Please ignore Ginko. He is feeding on responses to continue his rants. This request comes from Lauren. Thanks.
    PP2 - Get a 12 volt testlight, and unplug the small wire off of the starter. Hook the testlight to the battery earth terminal. Touch the pointy end of the test light probe to the small unconnected wire end, the metal part....
    Turn the key to start. Does the light illuminate?
    PP2 - I do not agree with the guy at Vauxhall.
    Question: Can you see the starter motor, when the bonnet is up?
  • Roberta Smith
    Roberta Smith May 11, 2010
    it still applies to newer cars... i'm presuming by what you are saying that you cannot see the starter for some reason ?
    Robert
  • Roberta Smith
    I have an old fashioned idea... have someone try to start it and smack the starter with a hammer... anything ?
    Robert
    If you can bump-start it, that indicates that the "start" signal from the keyswitch is not being sent to the starter motor. The security system that you have described may just be the culprit. Some security systems inturupt the start signal, to prevent theft.
    I would guess that there is something connected between the ignition switch and the wiring harness in the dash. What I would do, Pedro, is to pull the bottom dash panel off, and look at the wires that go to the ignition switch. See if there are some wiring that is connected between the dash harness and the ignition switch. If there are wires between the connector from the dash to the ign switch, follow them until you come up to a box of some kind. Then let me know what you see.
  • Roberta Smith
    define bumpstarting... do you mean when someone gives you a boost from their car battery ?
    Robert
  • 1,861 Answers
Glad you got it fixed.
Posted on Jan 19, 2009
  • Toyota Ed Jan 19, 2009
    Thnaks for the FixYa. Much appreciated!
    Brigadier General:
  • 5,158 Answers
Chances are you need to replace the starter then... if it runs slowly with no load... it likely won't even turn the motor
Robert
Posted on Jan 16, 2009
  • Roberta Smith
    Roberta Smith Jan 16, 2009
    Something i might add.... ed is very good at what he does. so weigh the information from the dealer who wants to make a profit and ed who is offering you his knowledge without hopes of compensation
    Robert
    President:
  • 1,450 Answers
The security system is shutting down the starter. is it factory alarm?
  • TripleTauto
    TripleTauto Jan 16, 2009
    if it is aftermarket alarm, under the dash you should see where they spliced into the starter wire coming out of ign just hook this back up.also look under dash for a small button this is the valet switch and if you push it it should reset and let you start. At least this is the way it is done in usa most of time
  • TripleTauto
    TripleTauto Jan 18, 2009
    have you checked the signal when in start position like ed said? the burning smell could be something in ign switch.i dont have any diagrams on this car so all i can tell you is to check the starter signal coming out of switch and if you have a signal there keep checking down the line till you lose it
01 Xterra dead battery. Tried jump, when I turn key alarm goes off blocks starting. Fobs wont disable/unlock. Only gets power to anti-theft. *Alarm doesnt go off opening door only turning key to start
You could try disconnecting battery, leaving overnight and then inserting ignition key and switching on before reconnecting the battery.
It has sometimes worked for me but in reality it seems you probably have an alarm immobiliser fault you need specialist help with.
Feb 13, 2018 | Cars & Trucks
I disconnected the battery to charge it. when trying to reconnect it, the alarm goes off. What should I do?
Daniel, On your key fob try turning alarm off, if not install battery, then start the car,shut car off and lock doors with remote this will reset alarm.
Mar 28, 2016 | Cars & Trucks
The car shut down the other day put new fuel pump in and still wont start. How do I turn off the alarm with out a fob
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
Find out what are the top reasons a car won't start and what to do in each situation. ...If they do then most likely your ignition switch is just fine (but it still could be bad ...replaced pump relay and auto shut down relay (ASD Relay) with new relays. ... Well, just the other day, after an 8 hr day at work, I went to start it and nothing ...
Why will my car turn over but not start? - CarGurus
www.cargurus.com > Questions > Chevrolet > Malibu
CarGurusApr 10, 2013 - I changed the fuel pump a month ago and two weeks later i got out then went ... when I get gas my car idles down and wont start immediately I start it go a little ... still the same issue we even replaced the fuel pump from a different store ....and my car over heated and after that day it turns over but won't crank ...
Can anyone help? My car wont start, it turns over ... - CarGurus
www.cargurus.com > Questions > Lexus > IS 300
CarGurusJan 3, 2014 - My car wont start, it turns over but will not run. ... cut off sequence in the manual also did the ecu reset and still didnt start. ... I will post if it was fuel pump or not, I have to wait a few days for ... 8 screws and then pull out fuel filter at an angle andreplace parts. .... It now starts but shuts down almost immediately.
Car Won't Start ' The Family Handyman
Dec 16, 2015 | Cars & Trucks
Will I be able to start and use my car if the key fob/plip isnt working?
everything should be ok as long as u got the key to start the car
Jul 07, 2014 | 1999 Renault Megane
Key fob alarm problem golf vr6
the immobiliser needs to be programed with diagnostic equipment
May 23, 2010 | 1997 Volkswagen Golf
How can i disable the immobiliser on my fto. The key fob has broken and it wont let me start the engine :-(
Is the alarm / immobilizer factory or aftermarket? If it's aftermarket you will either have to purchase and program a new key fob or completely remove the system and reconnect which ever cuts were made in the wiring.
May 15, 2010 | 1994 Mitsubishi Expo
My petrol Peugeot 405 (1995) seems to be immobilised altho when I enter the code on the keypad the light goes green , turn the ignition it makes the immobilised noise and of course wont start. The battery...
Have you tried turning the alarm back on so that it goes off again, lock and unlock the car with your fob now, then enter the code. This is because it might still be in the standard immobiliser mode.
Sep 07, 2009 | 1991 Peugeot 405
Car wont start or turn over.
Hi!
This problem appears to relate to your Immobiliser, When the alarm kept going off you couldn't shut it down with the fob? so after removing the power source to the alarm system and re-connection this fail to start because either the Fob has flat batteries in it or it needs re-coding.
I'm sure if you take the fob to any decent Electrical store or even your local car dealership they will change the batteries for you to eliminate that problem.
Unfortunately if the fob needs coding this can only be done via the cars own dealership.
There you go!
I hope this FixYa'd problem?
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 15, 2009 | 1999 Chrysler Sebring
Vehicle Parts & Accessories Logo
360 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
