Question about RCA D61W20 61" Rear Projection Television
When set cold it doesnt have pic
After sets been off for awhile. i turn it and sattelite on, the volume comes right on with no problems. the screen stays blank for 2 to 3 mins with a hissing sound from back. when the pic comes on the hissing stops but pic is flashing and rolling. it takes 1 to 2 mins for pic to come in or i can turn tv off then on and the pic is perfect untill set gets turned off for a long period.
  • RCA Master
  • 5,138 Answers
Check capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is Bad so replace other 2 as well.2200uf 16v and Two 220uf 35v.
Posted on Feb 10, 2009
Ln46a550 picture freezes when turned on
Firmware corrupted. Update the firmware. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | Televison & Video
AKAI MODEL CT3216. SET COMES ON AT PLUG-IN. PIC COMES ON AT 10SEC. NO PIC PROBLEM. SET HAS POOR AUDIO WITH NO CONTROL FROM CUSTOMER CONTROLS. SET CUTS OFF IN ABOUT 15 SEC. LEAVE PLUGGED IN AND IT COMES...
there may be some problem in the remote control board inside ..
either something is not connected or some thing has it burned out like capacitor ....
so you are not able to see the menu .....
Jul 03, 2008 | Akai Televison & Video
When you turn it on the pic is shrunk in the middle of the screen an no volume.but when it warms up. or you bump the right side of the set again full pic an volume.
armndmandy2,
This is a classic broken solder joint problem. I have a tip at http://www.fixya.com/support/r9091711-step_step_procedures_soldering which explains the proper way to solder and other tips and I have a troubleshooting tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which should help you find the broken joint.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 24, 2011 | Hitachi 50FX48B 50" Rear Projection...
Volume not working on lg neon
take out battery for awhile then put back in, if that doesnt work go to your settings and check your ring/speaker settings, an last of all if that doesnt work buy a new phone. good luck
Dec 30, 2010 | LG Neon GT365 Cell Phone
Set dont like to be cold
Resolder all pinns on FBT on the Deflection board.
Jan 16, 2009 | RCA D61W20 61" Rear Projection Television
Audio
Go to START, PROGRAMS, ACCESSORIES, ENTERTAINMENT, Volume control. With the volume control open, see if the volume is muted (Checkbox marked mute at bottom of Master volume) If it is checked, uncheck it, and you should have sound.
May 16, 2008 | Computers & Internet
SHARP AQUOS 32 INCH FLAT SCREEN
I had this problem as well guys. Just found a fix thought i'd share.
I simply went into menu>setup>reset . This will perform a factory reset, and you shouldn't have that K or the volume problem anymore.
I tried all the fixes involving volume- input- nothing worked. I tried volume- ch- but that K never changed colours.
It all came down to a simple menu option reset.
Mar 29, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Can't set clock
hello Have radio on and then you have to hold down the SEL button on left for a few seconds. Then it will say "SET H" which is hour and turn volume dial left or right to move up or down. To set the minutes push either the left or right buttons on the selector on the far right. You can switch from minutes to hours here too. And once at "SET MIN" turn the volumes dial to go up or down. Hope it helps!! Took me a awhile to figure out (no manual here)
Dec 06, 2007 | JVC KD-S890 CD Player
JBL CREATURE II Computer Sattelite Speakers Sound Problem
check on the speaker software were you can set master volumeetc. check for balance volume .
Oct 27, 2007 | JBL CREATURE II Computer Speakers
RCA D61W20 61" Rear Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
