Question about NEC / Cirrus Logic Triple VGA Chip
HP DV6000 PROBLEM WITH VGA CHIP
I HAVE HP DV6000 I HAVE PROBLEM WITH MY VGA CHIP HOW CAN I FIX THEIS I CAN TAKE ALL PART IS NOT HARD FOR ME
CO I AM PRINTER TECHNICIAN I WANT KNOW SHOLD I CHANGE THIS CHIP OR USE HOT AIR ON IT OR REPLACE THIS CHIP AND HOW CAN I FIND THIS CHIP THANKS
  • 59 Answers
Since this is an on board video chip you can't change it out or get a new grapics card. The HP DV6000 doesn't have a graphics card adapter in it. So your best bet would be to replace the motherboard.
Which you can search for online to buy.
Hope this helps.
Posted on Mar 02, 2009
Hp dv6000 attempts to start led lights come on then shuts down repeats this process
The hp dv6000 has a video card issue that is very comman the cpu heatsink and the video card and conncted to the same copper heatsink and what happens is the video card overheats and the pins that are soldered to the board come loose now there is a couple of ways to fix it option a is to take the laptop apart and remove the motherboard and heatsink and the cpu chip then locate the video chip and isolate the video card and heat it up to remelt the solder points this can be done by taking a aluminum can and cuting out the square that is same size of video chipthen with a heat gun heat up the chip so the solder joints remelt to the board but BE VERY CARFUL IF YOU OVER HEAT THE CHIP IT WILL MELT once the chip has cooled then reistall your cpu chip add new thermal paste and get a flat square piece of copper the size of the cpu chip and put it on the cpu chip then add more thermal paste and put the heat sink back on and reassemble the laptop and if you didnt damage the chip it should fire right up option b is to buy a replacement motherboard that has the upgraged heatsink installed and put that in but make sure yoyu order the right board check the replacement part number sticker on the motherboard and make sure yoyu order the right one i have done this process to about 200 of these hp dv6000 and they are still working today
Jul 07, 2012 | HP Pavilion dv6000z Notebook
My dv6000 will not come on, the lights come on fro about 2 sec. the shuts down. I replaced the motherboard but still will not power up.
You are in for a rough fix. See the HP forum and follow the directions on this web posting. Get a PC geek to help.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1269377543004+28353475&threadId=1147659
Search for the date given below:
Nov 22, 2009 16:10:23 GMT Unassigned HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described in the previous posts are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Mar 23, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hi, I have an HP pavillion dv6000 and the problem is that it doesn't start, i have just bought a new ram, but it still doesnt start, can you please help thanks
These Laptops have an inherent problem with the Video chip. If the computer is powering on but you are not seeing a video on the screen, try using an external monitor on the laptop vga port. If you can get a picture on the external monitor, you have an issue with your screen, and it needs changing. If you cannot get a picture on the external monitor, your video chip is bad and the laptop is finished. Reflowing the graphic chip is usually useless.
Good Luck
Sep 27, 2009 | HP Pavilion dv6000z Notebook
Upgrade for dv6000 laptop (from 443775-001) motherboard
actually mr hp pro your wrong ....the 443774-001 hp motherboard will fit in that case i did that and my laptop works fine even more so better than before. I am a local computer tech from benton mo. and i will be helping others from people like you whop try to get people to spend all kinds of money when they dont need to and by the way that motherboard i mentioned goes for about 68.00 on ebay!
Jul 20, 2009 | HP Pavilion dv6000 Motherboard
Is it difficult to replace a motherboard to HP Pavilion dv6000?
To rate it from 1-10. It's a 6.
You got to watch out for the ribbon cables connectors.
Two person will make it easier. The one with good eye sight and small hand should undo the ribbon connectors.
HP DV6000 has many problem with bad video chip problem.
The only way to fix it cheap is to swap the board.
Jul 09, 2009 | HP Pavilion dv6000 Motherboard
Hp pavilion dv2000 notebook will not boot up
Go to this Hp website for you could have a grapgics chip fault. One way to test is to plug a VGA monitor into the VGA outlet port on the upper left side of you laptop and start it up. If you get a clear display you have a screen problem - next step remove the external monitor and again boot up but in a darkened room to see if your backlight is off - if you can just see the HP logo in the back ground then your backlight has failed or more rightly - the backlight micro switch under your R/H hinge has failed. A cheap fix. If there is no display external or TFT your Nvidia graphics chip has failed. m/board replacement required BUT you may qualify for free m/board replacement under Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 Series Notebook PCs - HP Limited Warranty Service Enhancement go to this site below to see if you qualify
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 07, 2009 | HP Pavilion dv2000t Notebook
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
2,077 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
