FixYa.com
Tags:
PC Connection Ethernet Patch Cable
Netgear ethernet connection
posted by english on Jun 17, 2007
I am plugging in my connection direct from a desktop. It is sending but not receiving.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 30, 2008
Not Rated (0)
HooperCJ
Rank:Wiz Wiz
Rating: 81%, 21 votes
Make sure your cable is fully inserted into both the modem the router. also, ensure that you connect your modem to the router, make sure it's in the "internet" or WAN port (same thing, different names) and not into one of the PC slots (normally numbered 1,2,3, etc) and vice versa for connecting your PC to the router.
This is all assuming of course that you're connecting to a router / switch of some sort. if not (if you're trying to connect 1 PC to another) then you need what's called a crossover cable.
also, when you plug in, do you see a "link light" (usually indicated by a green LED either on the front of your router or on your NIC if a good connection is established (most likely you won't be getting this if you're not communicating, but if you are then knowing that definately helps to narrow down the possible problems). If you don't have a link and you have an extra cable handy, try using that one (mechanical failure is a fairly common problem, even in brand new components)
If you're still not fixxed and have any more information about what you are trying to do / what you have done, please do post that information.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 18, 2007
Not Rated (0)
jtra
Rank:Guide Guide
Rating: 92%, 41 votes
How do you know it is sending? Connection stats in Windows? Are you plugging into a netgear router? Is the router connected to any other PCs and what type of modem do you have (connected to the router, I assume)?
Solution #3
Not Rated (0)
quicway
Rank:Master Master
Rating: 81%, 14 votes
maybe plug it in the wan port. and not the 1234 ports
Solution #4
Not Rated (0)
wacompdude
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
What is the model # of your NIC card? Also what is your OS?
Can you Help with these Network Cables problems?
Network Cables
how to set clock
I purchased a Vextra Digital... Answer This...
Network Cables
com port missing?
I am trying to connect my... Answer This...
Repair Service
Find Network Cable Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
