Question about Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool Gas Range Model GW395LEPB
I just burnt a cake that I make regularly and needs 1 hour in the oven at 350 degrees, it burnt after 30 minutes! Something is very wrong. It also shut itself off and showed an error message with a F in it but I'm not sure which number came after it! I also have a common problem with this range that when I preheat it, some of the time after the 10 mins or so of preheating it will show it is on but it won't have heated up at all. Are these two separate problems or could they be related. I read on another posting that my first problem could be the oven tempature sensor, does that sound right? Could there be something else that needs repair too? Any help would be greatly appreciated - tnx:)
  • 409 Answers
SOURCE: whirlpool gs475lems range oven problems
it means bake range over temperature.
have a technician check out the oven temp sensor. you may have a short in wiring or it may need to be replaced.
if problem still persists, replace the clock.
Posted on Sep 13, 2008
  • 10865 Answers
SOURCE: Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
Posted on Apr 01, 2009
  • 10865 Answers
SOURCE: Whirlpool Super Capacity 465 Electric Range not heating properly.
Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on May 29, 2009
  • 58 Answers
The first thing you will need to do is to verify that you have 230 volts at the outlet. Chances are pretty good that the unit popped one of the double pole breakers. Check the breaker and reset it if you find that you only have 120 volts at the outlet. If after finding that you have only 120 volts and you've reset the breaker then the problem would lie with the breaker needing replacement. If however you have full 230 volts available at the outlet then additional troubleshooting would be needed. Hope this helps... Bill
  • 43 Answers
SOURCE: Ge Oven will get hot on Broil, but won't preheat
check lower oven element,
Posted on Oct 10, 2009
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
Whirlpool gas oven is taking three times as long to cook something,what is wrong?
have you checked with an oven type thermometer for 350 degrees against the setting of 350 degrees,if its off very far then its the oven temp sensor in the upper left middle or right rear wall of the oven thats bad it looks like a small pencil type rod 2" to*' long it merely unplugs off the oven s control panel in the rear,you can test its resistance also to get an idea if it is your culprit,otherwise the oven element could have a hot spot in it and not letting all the current thru to properly heat the element,it will be dis-colored in that area
Nov 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool SF36 Gas Oven - F3 F2 ERROR above 350 degrees
Unplug the range.
The oven temperature sensor has failed and must be replaced.
Remove the racks. Remove the temperature sensor located up high on the back wall of the oven.
It is a short thin round piece of metal.
Feb 13, 2010 | Whirlpool SF369 Gas Kitchen Range
oven senor not working right . it may have carbon that need removing or it may just need changing due to breakage
Feb 13, 2010 | Whirlpool SF367 Gas Kitchen Range
Temp on oven is not correct
Good Evening.
I would make sure that the conversion kit was the correct kit for your stove. Also, if it is not heating properly I would call the gas company and tell them the conversion did not work and they need to double check their work (at no charge). If everything is in order proceed to the next step below.
You can try removing the Oven Temp control. There is an adjustment on the knob which will vary the temp + or - 75 degrees F or so.
Procedure: Preheat your oven for 350 degrees F. Give it a good 1/2 hour to 45 minutes and then pull the knob off (usually held on with a set screw) You will need a thermometer that will go up to 500 degrees (I use an electronic one but you can use any kind as long as it is within the ovens temp range. If the oven is underheating simply turn the oven control stem to a higher setting, say a 50 degree incrament. Wait another 1/2 hour and measure temp inside oven. Keep in mind when you open the oven door it affects recovery time, etc so 30 minutes between a measurement and adjustment should suffice. Once you have adjusted the temp control to your target temp of 350 degrees look on the back of the knob and see if there is a stop adjustment. There is a chance the temp control knob could be setup differently but the same philiosphy/procedure will be similar.- the adjustment could be on the stem itself instead of the knob.
Also keep in mind that the oven temp will fluctuate from high to low as it tries to adjust to the temp it is set at. That is why it is very important to give the oven time to cycle low to high when you incrament the temp control. Hope this helps and good luck! Gary
Mar 14, 2009 | Whirlpool SF325 Gas Kitchen Range
Oven takes a long time to preheat
You don't list a full model number or how old this range is, or how long / how often you have this problem, but generally it sounds like the oven ignitor is not quite drawing enough amps to allow the gas valve to open regularly. It could be a low voltage related issue, but most likely is a failing oven ignitor. ( WB2X9154)
Sep 04, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Jan 11, 2008 | Whirlpool GS460 Gas Kitchen Range
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool GS475LEKS Gas Kitchen Range Logo
96 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
