Question about Jabra BT350 Bluetooth Headset Headset
VBT2050 light will not stay on
Light is on when plugged into charger, light goes out when disconnected from charger
  • 25 Answers
Light is suppose to go out after leaving charger. try holding call button down till light goes solid and than follow adding new device on tools in your cell. go to blue tooth and follow prompts , also pass key is 0000 or 1234. good luck and dont feel intimidated by it if your not used to it it will get better.
Posted on Jan 25, 2009
My nextbook 7 will not charge. When I plug in the charger it would begin to charge for a dew seconds and then the charge will drop. I thought that maybe it was the charger, so I tried the charger on...
Is there an indicator light that comes on when the charger is plugged in. If so, does it stay on. If there is and it does then there may be a problem with the battery. If there is a light but it goes off when you wiggle the plug when it's plugged in, then there may be a broken connection inside where the charger plugs in to the socket.
Jan 02, 2015 | Tablets & eReaders
Pioneer r1 tablet won't hold charge
My Pioneer R1 Tablet ALSO will not Charge only works when plugged in if i unplug it goes off! Charging stays at 0%.
Mar 19, 2014 | Tablets & eReaders
I have a Minn Kota MK 460 on board charger that the number 1 red light is on and it is not charging that battery. When you hook up to the other 2 batteries the light still continues to stay on. I had the...
is this a 3 or 4 bank charger I had the same problem but my battery was bad if you don't have the charger on the battery it goes to you will have a red light if your battery are hooked in series to check your charger disconnect the cross over wire and put charger on battery see if red light goes out if so you have charger on wrong battery or you have a bad temp.sencer in charger cord on # 1 feed
Sep 26, 2013 | Boating
Anomalous charging behaviour :- a) plug in discharged battery b) starts off with the yellow light flashing as usual c) after a very short time the lamp goes off completely - instead of staying on...
Okay, might not be reading this right but here goes. If the camera shows the batteries as full then I'd go with that. The charger will come on for a few seconds even with a freshly charged battery because it take that long for the charger to realize the battery is already full. You can't feed an already full battery, so the charger is shutting off completely. Yes normally the light would stay on and the charger would continue to trickle a charge into it it until it is removed. In your case I think you have those batteries stuffed to the gills so the charger is shutting right down. One of the problems with these batteries is as much as the manufacturers deny it they form a memory. Best thing to do with these rechargeable batteries is drain them right down and then replace with a freshly recharged battery.
Dec 17, 2010 | Nikon MH18a Battery Charger
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
When charging my H710 bluetooth, do I have to wait until the green light goes off before disconnecting it from the charger? Thanks
No, you don't have to wait. The green light doesn't actually go out. It stays green until you disconnect the headset from the charger.
Jan 10, 2010 | Motorola Mobility H710 Bluetooth Headset
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Jabra BT350 Bluetooth Headset Headset Logo
113 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
