Question about HP 510 Notebook
Windows will not boot
Have you ever seen the userinit.dll failed to load error message.
it doesn't even let me get back to the log in screen to run any repair from within windows because i cant log on...
i have tried F8 option safe mode and last known good configuration but all lead back round to the same screen (can sen you a picture soon to demonstrate this problem if you like)
i have HP recovery CD p/n 409456-022 that came in the box with it but that requires that i can get into windows in order to run its repairs. i need a fix thats a level above that
please help me
    Problem Solver:
  • 82 Answers
When u turn on the PC enter the BIOS setting in that enter boot first from CD .............. & save the changes. When u boot again insert the recovery cd & try to recover if this also does't help go for fresh installation of Operating system..............................Sameeraryan
Posted on Jan 17, 2009
Hw to remove run DLL error in microsoft window 8.1
run.dll is a DATA LINK LIBRARY FILE if it is sikped in installing windows {or} other any software ,malware,adware virus problem you can fix it by using DLL suite { the dll suite download and install it will have a lot of serials keys in serial.ws.com } you will enjoy the features of windows
Apr 06, 2015 | Microsoft Computers & Internet
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Microsoft Windows XP Professional
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Run DLL, VTURQjKC.dll problem
smash with hammer and try again
Apr 21, 2010 | Computers & Internet
Computer loads personal settings and then logs off instantly
Sounds like a malware issue I've seen before:
XP logs user off immediately when the user tries to log in - can't get to any desktop
Allegedly 3rd party advertising software Blazefind (homepage and searchbar highjacker)
Fix:
Boot to the Windows XP CD (RAID systems will need the RAID driver floppy during the bootup - hit the F6 key when directed in the bottom message).
Enter the Recovery Console by choosing 'R' at the Welcome to Setup screen.
Choose the OS shown (1) and hit enter.
Hit enter for a blank password if asked for one. If this isn't accepted, make sure that the user is using the correct XP CD (using a PRO version CD for a HOME version install or visa versa will result in a password rejection. If the user has upgraded to PRO over a HOME edition, try booting the HOME CD). If the CD is correct, and the user can't produce the correct Administrator password, then a clean reinstall of the OS (with full data loss) becomes the final answer.
Assuming the user now sees a command prompt, type "CD %systemroot%\system32" (without quotes) and hit ENTER. Normally the %systemroot% default is "c:\windows\" but this depends on if the system defaults were kept or changed during OS installation, of course.
Type "COPY USERINIT.EXE WSAUPDATER.EXE" (again, without quotes) and hit ENTER. This makes a copy of "userinit.exe" and simultaneously names the new copy "wsaupdater.exe".
Type "EXIT" and ENTER. Remove the XP CD while the system is restarting.
The user should now be able to log in normally... but there is one more thing that needs to be done or the issue will repeat itself when the user runs his anti-spyware program again.
Once logged into an administrator account, click the START button.
Choose RUN from the Start Menu.
Enter "REGEDT32" in the OPEN window (notice there is no "i" in edit) and click OK.
By clicking on the + signs next to each branch, click through the tree in the left pane until you get to
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\WINLOGON
Click on the WINLOGON folder in the left pane tree, so that it is highlighted.
Look for "UserInit" in the right pane. It should have a value of "C:\WINDOWS\system32\wsaupdater.exe," (yes, there is a comma at the end of the value). Double-click on "UserInit" and carefully change its value to "C:\WINDOWS\system32\userinit.exe,". Click OK.
Close the Registry Editor. Reboot. Fix is complete. Anti-spyware programs will probably identify and remove "wsaupdater.exe" but the system is no longer using it.
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Can't log in
The repair CD that came with it doesn't need to be run from inside Windows. All you need to do is turn the machine on, and boot the machine with the CD itself (just as you would if you were installing a fresh copy of Windows).
Jan 15, 2009 | HP 510 Notebook
M3plugin.dll
please tell us how to resore requird dll for error
C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
Sep 10, 2008 | Computers & Internet
HP 510 Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
