Question about LG 16x EXTERNAL RETAIL Burner
Region setting?!! my dvd player does not read dvd and says that the region setting is not configured, i have tried to change it in the device manager..... no luck, i have disconnected it and reconnected it ..... no luck, pls help
    Genius:
  • 2,985 Answers
Read the Manual and/or contact Technical Support at LG
Posted on Jun 18, 2007
Reads cd but not dvd
If this DVD drive does not read DVDs, the Region setting may not be configured for your DVDs.
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From:-
www.dvdfab.com/products,free.htm
Mar 24, 2012 | Computers & Internet
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
My Presario CQ61 has changed DVD zones the maximum number of times allowed. It is now set to a zone that prohibits me playing anything from Australia.
Copied from somwhere else...
I came across a web site called DVDRhelp.com which tells how to reset the region codes for software DVD players.
http://www.dvdrhelp.com/play
" Q: How do I make my DVD drive region free (remove region codes/country codes/zone locks)?
A: Use DVD Region-Free to make your region locked DVD drive and your software player region free. You can also 'patch' your DVD drives firmware, you can also try a patched DVD drive firmware (it is freeware, but may be a bit tricky and 'dangerous').
http://www.dvdidle.com/dvd-region-free.htm
http://forum.firmware-flash.com/dl_all.php
Q: How do I make WinDVD,PowerDVD,Win2k region free?
A: Use DVD Region-Free to make your software player region free. Or use DVD Genie (freeware) to make your software DVD Player region free.
http://www.inmatrix.com/files/dvdgenie_download.html "
Side note: firmware is "miniature" software which runs an electronic device. Some electronic devices have updatable firmware that can be downloaded from the manufacturer's web site and re-programmed into the device. This is referred to as flashing the BIOS (Basic Input Output System) or EEPROM (Electrically Erasable Programmable Read-Only Memory). A word of warning: if a firmware upgrade is interrupted due to a power outage or computer freezeup, the device may cease to function.
Dec 22, 2010 | Computers & Internet
How do I set acer aspire dvd region to read all dvds?
Click Start
Click Settings
Click Control Panel
Click System
Click Hardware
Click Device Manager
Click the '+' to the left of 'DVD/CD' branch of the hardware tree.
Double-click your DVD device.
Change the region.
Note that you can "change region" only about 5 times, before the DVD will "lock" into a specific region.
Apr 18, 2010 | Acer Aspire 5720-6661 Notebook PC
My wife bought a TV series on DVD while she was in the Middle East and now that she brought them back to Canada we are not able to play them. How do we deal with this?
Region-free DVD players are sold through various venues.Try playing it in a computer DVD player/burner. Some burners are region-free. Some software can copy your purchased disks, removing the region code in the process.
Sep 01, 2009 | Televison & Video
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Want to play dvd's from any region. My JVC XV-S332SL/XV-S402SL DVD Player is restricted to Region 4
hi you can try this it been tested and will work if done correct we just tested this and had no problems unlocking this in the shop lol.
1. Power the player off.
2. Press and hold 'DVD Menu' and 'On Screen' on the player.
3. Power the player back on.
4. Release both buttons.
5. Press Standby. The display should now read either TEST 2, TEST 4, or TEST 6
depending on the machine's current region setting.
6. Press DVD Menu twice on the player.
7. When the display reads 000 5858 use the up and down buttons to change the
000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until
they read 0000 for Region Free, 0001 for Region 1, 0002 for Region 2 or 0004 for
Region 4....
NB: DO NOT Use Region 20!!!
9. Press Enter on the player.
10. Press Standby.
11. Wait 5 Second.
12. Press Standby again.
Some titles may not play in region free setting. If this happens select the
needed region.
JVC XV-S332SL, , XV-S402SL,
riz.
Aug 17, 2008 | Televison & Video
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Dec 12, 2007 | Oppo Digital DV-980H DVD Player
Incorrect region code DVD player
if you use a PAL broadcast system where you live ..Use the menu on dvd to set it to PAL system..If you use NTSC change it to NTSC .
Dec 05, 2007 | Televison & Video
LG 16x EXTERNAL RETAIL Burner Logo
19 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
